Got my "new" LSBPV installed! Pics!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CdnSldr, Jun 21, 2011.
  1. Jun 21, 2011 at 6:45 PM
    CdnSldr
    CdnSldr [OP] Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    Soo after picking up my beauty last summer I noticed that the load sensing brake proportioning valve was bloody rusty and then I tried to move the bar and she was pretty seized. I pinched the rubber boot and heard rust crunching :mad:
    I had to make an emergency stop on the highway once and having the back end come around on me was not a nice feeling. I started looking to replace this bad boy. From toyota this part cost about $340 :eek: No thanks!
    I started shopping around the local junkyards but everything I found was in just as bad shape. I stumbled upon a certain gentleman that was parting out his tacoma here on TW. :D
    I got a used LSBPV for a reasonable cost, got her all cleaned up and coated in red oxide primer. Never to rust again!:cool:
    Here was the old one
    Used one after the wire wheel treatment and some rust primer
    Installed with some brake line repairs. Man it is a PITA flaring the lines while they are still under the truck.
    Just a tip when re-installing brake lines whether they be old or new, after they are tightened smear some grease or anti-sieze where the line goes into the fitting. It will keep corrosion at bay and prevent the lines from twisting and snapping next time they need to be disconnected.
    Also scrubbed her down in the bath today. Here is a pic for you all.
    Cheers!
  2. Jun 21, 2011 at 6:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Well Done!
  3. Jun 21, 2011 at 7:07 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    good job & nice truck!
  4. Jun 21, 2011 at 8:56 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Sweet lookin' truck man,
    definitely one of the nicest 96's I've seen on this site.:)
  5. Jun 21, 2011 at 9:45 PM
    el dudarino
    el dudarino Well-Known Member
    damn...glad I live down here in the rust free zone. I'd never want to drive my truck up north except for sunny days.
  6. Jun 22, 2011 at 1:31 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    yikes first picture doesn't look good. glad you change it right away.
  7. Jun 22, 2011 at 12:51 PM
    CdnSldr
    Josh
    It feels like a constant fight with the salt! I wish the previous owners would have got the underbody oiled:(
    Thanks for all the comments! Ive put a bit of work into her since last year! Mainly just extended preventative maintenance.
  8. Jun 22, 2011 at 4:06 PM
    Tacomadude89
    Austen
    California
    Give your truck a good underbody washin' frequently I guess.
  9. Jun 22, 2011 at 5:26 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
