Got my spring tsb approved. Question on billies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Sep 18, 2010.
  1. Sep 18, 2010 at 12:20 PM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    Just got the spring tsb approved after mild hassle. Sa lectured me on difference between tsb and recall and said I'd have to bring back motorcycle loaded on back to prove harsh ride. After politely refusing to spend any more of my time proving anything and asking for toyotas number, he said parts are ordered.
    I want to go with billies up front. I know i can get them from down south motorsports, but question is whether he would put them in for me? If yes, would he hand me the new trd front shocks that come with the tsb? I'm capable of installing billies myself, but don't want to give the dealer a reason to refuse.
    Thanks!
  2. Sep 18, 2010 at 12:38 PM
    The Yellow Dart
    The Yellow Dart Well-Known Member
    Nick
    Seattle
    07 //SR5 4x4
    OME 2.5" Lift, TC UCAs, LEER Cap, Sleeping platform, PA20-TOY
    They'll probably do it, but charge you the labor.
    As for the TSB shocks, I would imagine you could get them -- since it's now your part.
    The only major snag I can see is that they would have to be billed as 2 different jobs. The TSB gets billed as Toyota Service and the Billie install would be outside service. The outside service gets billed at a higher rate.
    There also might be a stipulation in the TSB that once the parts are installed, they need to be inspected and tested before it is complete. So they would have to install, inspect and test the TSB shocks, then rip them out to install the Billies.
  3. Sep 18, 2010 at 12:41 PM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    Not sure what kind of Taco you have, but if you already have blue/yellow Bilsteins, they will not be replaced.
  4. Sep 18, 2010 at 1:48 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2008 P71
    Yes
    My dealer refused to install any aftermarket parts and stated they would only install toyota parts. I was looking to do the same.
  5. Sep 19, 2010 at 3:58 AM
    xxaarraa
    OK, I think I will install the Billies myself. I am going to order them from Downsouth and put them in.
    Will they hassle me about putting in the rear springs and shocks while leaving the new billies intact up front? I don't want them to rip out my billies etc. and cause more headaches.
    Thanks guys.
  6. Sep 19, 2010 at 4:05 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^
  7. Sep 19, 2010 at 10:50 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Let them do the entire TSB then install the bisteins after you get it back. If they already tried to give you a problem, don't give them a reason to not do it.
  8. Sep 19, 2010 at 11:18 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    excuse me for being dumb, but ive seen this so many times and idk what it is? what is tsb and what does it do?
  9. Sep 19, 2010 at 4:40 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    http://www.tacomaworld.com/forum/new-members/7109-rear-spring-tailgate-tsb-quick-reference.html
    Technical Service Bulletin. It's like a weak recall, but not everyone will get it.
    The weak spring TSB replaces the rear leaf pack on TRD trucks with a stiffer leaf pack (has an added helper leaf) and the shocks & leaf on non-TRD prerunners and 4x4s (adds the shocks that came with the TRDs). The dealer inspects the truck to determine if it applies to you.
    For the OP, I doubt they'll give you the shocks if you have them install the 5100s. They may install the 5100s but many won't. If you want the shocks, I'd get the TSB done first and then change out the shocks for the 5100s. I know they won't just give you the parts to do the job yourself.
  10. Sep 24, 2010 at 2:19 PM
    xxaarraa
    Folks - here is the update: Just picked up my truck after having the spring TSB done and SA said that my stock shocks were already the updated spec and did not need to be replaced. I do see the new 4 leaf spring pack in the back, but he said the part numbers on the new shocks were exactly same as old ones, so they didn't do the shocks.
    Since they ordered the necessary parts and did change out the springs, I don't have reason to suspect they were skimming on me. But has anyone heard this one before???
  11. Sep 25, 2010 at 11:31 AM
    Evil Monkey
    Robert
    Escondido, CA
    Do you have a TRD truck? If so, they won't replace the shocks. The TRD shocks are yellow and blue.
  12. Sep 25, 2010 at 11:43 AM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Since you're swapping out the shocks to 5100's anyway, does it even matter? The main deal is you got the 4-pack leafs now and on their dime. Now just get that shock swap done and another wheel alignment...you'll be sittin pretty!
  13. Sep 25, 2010 at 11:47 AM
    xxaarraa
    Nope, doesn't matter. But it's a trust thing, I was just wondering if the dealer story was legit, that's all. Going to be putting in the billies up front pretty soon, thanks all.
  14. Sep 25, 2010 at 1:27 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You must have a 2009 or 2010. The shocks do not get replaced for these model years per TSB.
