Got new tires and now truck shakes...
Discussion in 'Wheels & Tires' started by TacoEnthusiast, Oct 18, 2009.
  1. Oct 18, 2009 at 12:44 AM
    TacoEnthusiast
    TacoEnthusiast [OP] Active Member
    Bobby
    Wichita, KS
    05 PreRunner SR5 TRD Sport
    none, nada
    I just got a brand new set of General Grabber AT2's. Granted my previous tires were getting pretty bald, ride was very smooth and had no problems. After the new tires were installed I noticed that as I accelerate over 40 mph or so there is a shake in the steering wheel. I am trying to figure out if its just me or if they did not balance my tires correctly. My girlfriends dad got me a deal at one of his friends' shop so I don't want to go in and complain unless I'm positive it's their fault. Any help appreciated.
    Edit: I realized before I bought the tire that the ride would be different. I just don't know if this is "different" or a bad installation.
  2. Oct 18, 2009 at 1:14 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Check balance again. Maybe they balanced it as static instead of dynamic. But even though it was static balance there shouldn't be any vibrations if it was done correctly. But then again a/t tires are a real bitch to balance. Check out dynabeads, that might help.
    http://www.innovativebalancing.com/
  3. Oct 18, 2009 at 2:30 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sounds like a balance issue. I'd have it checked again or, swap the front and rear tires because it might just be one tire causing the issue and it might not be felt when on the back. My BFG MTs are that way. There was a slight shake and pull after I got them put on, but when I did my first rotation and put them on the back everything went away and they were nice and smooth.
  4. Oct 18, 2009 at 6:08 AM
    wnealw
    wnealw Active Member
    Fredericksburg,Va.
    08 tacoma 2wd
    scanguage,thrush turbo muffler wellded in.
    try retorque the wheels. somebody over tighten one or two lugs more than others ?????
  5. Oct 18, 2009 at 6:29 AM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    Find someone who can do a roadforce balance. I fought with some wheels for 20K miles. New roadforce balance and bam, smooth ride. If you can't find a place, go to tirerack.com and check their prefered vendor list
