Got new wheels/tires on my 2WD Tacoma
Discussion in 'Wheels & Tires' started by hammerdog, Sep 17, 2007.
  1. Sep 17, 2007 at 7:13 PM
    hammerdog
    hammerdog [OP] Well-Known Member
    Last month, I posted regarding getting some new wheels.
    http://www.tacomaworld.com/forum/wheels-tires/2522-wheel-upgrade-07-tacoma-reg-cab-2wd.html
    Finally got rid of my 15” steel wheels and went to 16” wheels on my 07 Tacoma 5 lug 2WD. I bought these wheels off of ebay and they are originally for a 02-04 Camry/Solara/Sienna. I only went up one size to keep the speedometer reading close to the OEM reading. Overall, the truck has a better ride now, not because of the wheels, but because the new tires are wider, more rigid and have a 800 wear rating with 90K warranty.
    I also had to change the TPMS over to the 20-degree sensors on the new wheels. I still need get the new sensors scanned and entered in the ECU by Toyota.
    The center bore and bolt pattern on these wheels are the same as the 5 lug steel wheels. The only difference is the offset, which is 50 ET on the new wheels. Thanks spp for this information.
    Old wheels/tires -15 X 6 wheels 215/70/15 OEM Firestone Destination LE tires (8.46 in width/26.85 in diameter)
    New wheels/tires 16 X 6.5 235/60/16 Michelin HydroEdge Tires (9.25” width/27.10 in diameter)
  2. Sep 17, 2007 at 7:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    nice...definately look good on the truck
  3. Sep 18, 2007 at 5:03 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Those look great! :thumbsup:
    Any vibrations or balancing issues?
    Those things almost look like they are meant to be on the truck from the factory. Great job finding those. How much is Toyota going to charge you for scanning the sensors into the ECU?
  4. Sep 18, 2007 at 10:01 AM
    hammerdog
    Thanks for the comments. I had no vibrations or balancing issues. The truck has a more solid ride now, better cornering, more control, mostly due to the better tires. I think the OEM tires were softer rubber and the new tires are more rigid.
    I am not sure how much Toyota will charge to scan and enter the new sensors. It is only a (15) minute job, they have to scan each sensor, then manually enter the (7) digit code from each sensor including the spare into the ECU. I would think the minimum charge would be one hour of shop labor, but I will post what I paid after I get it done.
  5. Sep 19, 2007 at 11:19 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Wheels look good and i really like those tires
  6. Sep 19, 2007 at 2:47 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Nice! You get to keep that factory look since they're still toyota wheels. Just much better looking wheels.
  7. Sep 21, 2007 at 4:10 PM
    hammerdog
    Took my rig to the local Toyota Dealer service department to get an estimate on the cost of scanning and entering the ID numbers on the new sensors. They were not busy and did the (4) wheels and the spare for $47.00 while i waited. (30 minute shop labor charge)
    They even washed my truck and considering I did not buy the truck there, I felt it was a fair price. The annoying yellow sensor light has now disappeared from the dash.
    Next mod is a stereo/speaker upgrade!
  8. Sep 29, 2007 at 9:06 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    wheels look good, but i REALLY like those tires.....
    i just got new wheels/tires myself and it made me love my taco all over again, im sure you feel the same.
    they look good man!!!
  9. Oct 1, 2007 at 9:39 AM
    GTiVR6r
    GTiVR6r Big Cat Chew Toy
    Carpentersville, IL
    07 Tacoma Access Cab 2.7L Impulse Red
    Really Nice wheels! Good find!
    Do you know by chance what the lug patern is? 5x100?? 5x110??
  10. Oct 1, 2007 at 12:14 PM
    hammerdog
    new wheels are the same as a 5 lug tacoma (Reg Cab 2WD)
    5 x 4.50 or 5 x 114.3
    60.1 mm center bore
    offset 50 ET (offset on steel oem wheels is 40 ET)
  11. Mar 7, 2008 at 6:25 AM
    willtusss
    willtusss New Member
    Are these the same on the 2008 tacoma 2wd ascesss cabs??
  12. Mar 7, 2008 at 12:11 PM
    hammerdog
    no, these were after acquired wheels to replace the steel wheels on my 2WD..... i have since bought a 4WD Tacoma access cab
  13. Mar 7, 2008 at 12:31 PM
    willtusss
    Yes but I was referring to this information.
    60.1 mm center bore
    Would the same size fit the 2008 2wd access cab tacoma??
    Or are sizes different for 08's??
  14. Mar 7, 2008 at 1:13 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Those wheels and tires really sport up the truck, E-bay is great !
  15. Mar 7, 2008 at 10:22 PM
    hammerdog
    Willtusss, that same size will fit the 2008 Tacoma 2WD Access Cab, nothing has changed....
    However, they will not fit a Tacoma 2WD Access Cab Prerunner, because the Prerunner has 6 lug wheel.....
  16. Mar 15, 2008 at 11:56 AM
    iicei
    iicei New Member
    07 Taco Ext Cab
    I put new 7x17 07 Camry wheels with 235/60r/17 Kumho Road Venture APT tires.Wheels have no sensors but I have not received any TPMS warning on in dash display. Added 1 leaf spring on rear at Long Beach Spring.
  17. Mar 15, 2008 at 12:11 PM
    Dutch
    Dutch Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    I agree.........those wheels really change the look! Keep away from the curb when parallel parking. Nice job!
  18. Mar 15, 2008 at 8:31 PM
    L8Rmike
    L8Rmike Well-Known Member
    Goose Creek, SC
    08 White DC LB 4x4 sport
    Looks good. I have those tires on the wifes Sienna and there are great dry or rain and good in snow and ice (February trip to Indiana).
  19. Mar 16, 2008 at 5:30 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Looks good! I'll have to keep this in mind for when I wear out the stock tires in another 30K miles.
  20. Mar 16, 2008 at 8:12 AM
    spp
    spp OC, Kalifornia
    OC California
    How can you not be getting the TPMS light? Are you carrying the old wheels in the bed? How about some more info on the leaf addition. Pic, price etc. I have a shell and could use a little boost.
