Got new wheels/tires on my 2WD Tacoma
Discussion in 'Wheels & Tires' started by hammerdog, Sep 17, 2007.
  1. Mar 16, 2008 at 4:42 PM
    TacoSter
    TacoSter Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    Hopefully not an issue?? Check the load rating on the rims... designed for a camry, rolling on a truck.... load rating should be stamped somewhere on the rim....
  2. Mar 17, 2008 at 8:19 AM
    spp
    spp OC, Kalifornia
    OC California
    Same wheels I think are used on the Sienna which is heavier than the Tacoma.
  3. Mar 24, 2008 at 3:56 PM
    XxMalfunktionxX
    XxMalfunktionxX Well-Known Member
    Orange County,California
    2008 4x4 TRD SPORT SR5 Double Cab
    K&N Drop in, Bilstein 5100's in front with Readylift kit on top for a 3 in. lift in the front and a 1 in. block in the rear. Next project is going to be TRD Supercharger and Camburg coilover long travel system with custom skid plate and tubes. Maybe some new tires and wheels then..
    Looks cool..
  4. Apr 1, 2008 at 11:52 AM
    surfingislife
    surfingislife New Member
    bone stock
    none...so far
    whats the biggest tires you can put on a 2wd taco? i got quotes on at least a 30" tire with a little bit of rubbing. im trying to stay away from getting a lift.
  5. Apr 30, 2008 at 9:08 AM
    JBeasty
    JBeasty Member
    Northern California
    08 standard cab, 2.7L, 4 sp auto.
    None yet
    I like this modification. I'm finding lots of 17" 5 lug, Camry/Solara/Sienna wheels on eBay (but no 15 or 16) - would these work? I wonder how big (in total diameter) you can go with the tires before you have to start worrying about clearance issues . . .
    Thanks, JB
    Opps, now I see the post directly above (duh) - but does this apply to the 2WD standard cab base model?
  6. Apr 30, 2008 at 9:56 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The base 2wd standard cabs and access cabs both use the same wheels.
  7. Apr 30, 2008 at 10:10 AM
    JBeasty
    JBeasty Member
    Northern California
    None yet
    Just did my very own (very unscientific) measurements, on my 08 Tacoma. My stock wheel with the low budget Firestone measures ~ 26" (with ~ 30# PSI). But my wheel well from street to bottom of fender is ~ 31". I wouldn't think anything more than 27-28" would clear without some rubbing . . . Am I missing something?
  8. Apr 30, 2008 at 11:12 AM
    Roland
    Rhode Island
    For every inch you increase the tire size it will raise the truck a 1/2 inch?
  9. Apr 30, 2008 at 1:18 PM
    JBeasty
    JBeasty Member
    Northern California
    None yet
    So then I guess my question is: How many inches of clearance (or suspension travel) do I need to safely allow for?
  10. Apr 30, 2008 at 5:36 PM
    JBeasty
    JBeasty Member
    Northern California
    None yet
    Cool! Thanks for the info. And you've never had any rubbing? I guess maybe if you were doing 50MPH, and turning, while crossing over railroad tracks! ;). My current tires are P215/70R15 - looks like I could go a fair amount larger. The stock tire/wheel combo just looks too small (to me), even on the standard cab.
    Did you notice much of a speedometer error? How does gas mileage read, higher or lower? (my little peanut brain for some reason can't comprehend the math involved). Sorry so many questions . . .
    JB
  11. Apr 30, 2008 at 9:54 PM
    JBeasty
    JBeasty Member
    Northern California
    None yet
    Thanks for your patience Dude. BTW - I grew up in the Oakland hills, and now live ~ 30miles NE of you. Small world.
    So far my MPG was only 20.5 on the first tank - but I'm guessing (hoping) that will improve once it's all broken in.
  12. May 18, 2008 at 5:14 PM
    tacoma man
    tacoma man Well-Known Member
    Rochester NY
    2018 Limited 4wd Magnetic Gray
    GM3BOW,
    About to take in a 99 tacoma trd v6 to be crushed. (THink it will fail). Has new goodyear 31x10.5x15 tires on it. Do you think I can fit them without a lift on a new 2wd access 2.7 auto? New rims too? Just sell them? Your truck looks great!
    Tacoma man
  13. May 22, 2008 at 8:40 PM
    Cusker
    Cusker Member
    So do you use your GPS to figure mileage per tank?
    It would seem to me since you've got oversized tires your speedometer AND odometer are going to be wrong.
  14. Jul 27, 2008 at 6:36 AM
    Synapse
    Synapse Well-Known Member
    Birmingham
    2008 Tacoma
    How did the financing go on that? Was it easy? I was thinking of upgrading to a prerunner, but wasnt sure what kinda hit I would take on trade being a 08. i know there is a 2k rebate right now on 08's. But that still isnt enough to offset the drive off lot hit.
  15. Jul 27, 2008 at 9:59 AM
    #35
    hammerdog
    hammerdog [OP] Well-Known Member
    I bought my 4WD Tacoma in California and at the time I bought, I got 0% interest rate for (36) months. There was only a $500 rebate when I bought mine and I went for the 0% interest instead of the rebate.
    The dealer was also trying to get me to buy a Tundra at 0% financing at
    (60) months with a 3K rebate, but the gas mileage on them was so bad, I declined.
  16. Nov 11, 2008 at 7:59 AM
    #36
    OLEFART
    OLEFART Active Member
    northern illinois
    09 base
    integrated sirius, tonnaue cover
    really like that a lot, i have an 09 reg cab in silver streak mica as well , hope you don't mind i'm gonna mimmick your idea, what did the new tpms set you back and are they oem or aftermarket
    #36
  17. Nov 11, 2008 at 7:06 PM
    #37
    hammerdog
    Because I went from steel wheels to alloy, I replaced all (4) tpms and they were around $77.00 each from 1sttoyotapart.com......very expensive, if you can find them on ebay, you can save a lot money....i tried ebay and at that time, i could only find a set of two on ebay and i needed four....
    #37
  18. Nov 12, 2008 at 6:14 AM
    #38
    OLEFART
    northern illinois
    09 base
    thanks , for the info,but i've been told that my tpms will work on some? alloys,i'm more confused than ever
  19. Nov 12, 2008 at 9:00 AM
    #39
    hammerdog
    Some folks modify them, turning them backwards and they work, some use some type of foam and get them to work......some just dont put them back on......i ended up selling my old tires and wheels, so i was able to justify the cost.....
