Got Real Stuck, Had A Blast....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Jun 13, 2013.
  1. Jun 14, 2013 at 6:56 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
  2. Jun 14, 2013 at 6:58 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  3. Jun 14, 2013 at 9:24 PM
    Bearcoatoffroad
    Bearcoatoffroad Well-Known Member
    Barry
    Rincon, GA
    '07 TRD Off Road 4x4 Double Cab
    2.5" spacer lift, Tundra wheels with spacers
    Not really how it works... Flat ground with roughly even pressure on each rear tire and roughly equal traction on each side a locker won't do much for you.. It would help a little by clearing tires that would normally alternate spinning left to right, but no such rule as 50% traction increase when you hit the button.
    Open diff, total force pushing vehicle is equal to wheel with LEAST force X2.
    Locked diff, total force pushing truck is equal to SUM of force from left and right tires.
    One tire on ice and one on pavement, open diff, truck will barely if at all move.
    Lock diff, truck moves like normal from tire on pavement. 50% more than almost nothing is still almost nothing.
    Locker is most useful when one tire has traction and one does not because of either surface of ground is different side to side, pressure exerted on tires is uneven, or both.
  4. Jun 14, 2013 at 9:31 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  5. Jun 15, 2013 at 4:46 PM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Meh it all works fine. The speaker is protected behind those plastic grilles, and the door locks are just a purely mechanical plastic mechanism. Not the first time I've powerwashed my interior either :p
  6. Jun 15, 2013 at 5:10 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :facepalm:
    I'm purely amazed at what I just watched and read. Please no one else follow in his steps
  7. Jun 15, 2013 at 5:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  8. Jun 15, 2013 at 5:28 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Hey, if they still work, fark it!
  9. Jun 15, 2013 at 11:02 PM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    Barely any mud on door panel= clean @ .07 sec. Into video.
    Another 43 sec. Of high pressure spraying for no reason = epic fail.
    Use a wet rag to clean that little bit of mud off. I predict another
    " warranty issue "
  10. Jun 15, 2013 at 11:18 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    OP said YOLO
  11. Jun 16, 2013 at 7:15 AM
    mrbadwrench
    Cleveland Ohio area
    Truck is way out of warranty.
  12. Jun 16, 2013 at 7:16 AM
    mrbadwrench
    Cleveland Ohio area
    You Only Lose Once? :p
  13. Jun 16, 2013 at 7:24 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    LOL, at power washing the door.
    I'm not hating, its your truck.
    Great story!
  14. Jun 16, 2013 at 8:13 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Also still 50% more than almost nothing is still 50% more. U never no how much traction u need to get moving. U don't need all it traction all the time u just need enough, just like u don't always need 236 HP, just enough for whatever is at hand. It may not have made enough difference but it wouldn't have hurt and it might have pushed him right to the amount that was needed.
  15. Jun 16, 2013 at 9:57 AM
    #35
    Aiacr
    Aiacr Member
    Ben
    Southern Maryland
    2005 SWB DCSB
    Debadged, Bilsteins set @ 2.5, Plasti-Dipped Wheels, Blacked out Grill/Emblem
    Great story!
    Not sure if I'd go as far as power washing the interior like that, but hell, if it works, and you're okay with whatever electrical consequences, then why not?
  16. Jun 16, 2013 at 10:04 AM
    #36
    OZ-T
    Peter North
    British Columbia
    Judging from this pic , I doubt I would have driven in there
  17. Jun 16, 2013 at 10:16 AM
    #37
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Oh hell. Of course it works. It's a TOYOTA, dang it!
  18. Jun 16, 2013 at 6:16 PM
    #38
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    Wow you guys are buncha negative nancys , my truck was underwater speaker fully submerged, water up to my knees in the cab, that was 2 years ago speakers works fine, truck runs fine. not to mention mine is a 98, so if they still build them like how they build them back then, he should be fine.
  19. Jun 16, 2013 at 6:24 PM
    #39
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    To each their own, but if I got that amount of mud on the inside of my door, I think I'd start off with a damp rag first.
  20. Jun 16, 2013 at 6:45 PM
    #40
    cgs2k2
    cgs2k2 old man
    some of you guys put your trucks through hell on the trails, but when it comes to spraying the door with water you get all bent out of shape? who cares. if the speaker blows, he'll get a new one. not a big deal.
