Got Shafted on PRO Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 58LesPaul, Jun 1, 2017.
  1. Jun 1, 2017 at 6:08 PM
    58LesPaul
    58LesPaul [OP] Well-Known Member
    Jeff
    Kentucky
    2013 Tacoma TRD Sport 4x4 DCSB
    2" Lift
    I bought what was advertised as a Tacoma Pro suspension on Craigslist. After installed I got zero lift on the front. Finally figured out it was a 4Runner PRO suspension, exact suspension as Tacoma PRO but shorter springs.
    I had 1" spacers on before I switched the coilovers to the PRO's and now I'm thinking of just putting those spacers on these PRO coilovers to get back to 2" lift since I also installed a 1.5" AAL to the rear. So now I'm 20.5" front and 24" rear. Does anyone see any issues with reinstalling the spacers on the PRO suspension?
    Thanks
  2. Jun 1, 2017 at 6:29 PM
    Pigpen
    Dan
    Northwest Montana
    1" spacer for 2" lift will probably make the shock the limiting factor in travel.
    tcjacado likes this.
  3. Jun 1, 2017 at 6:44 PM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    I'm pretty sure the 4Runner PRO shocks are the same as the Tacoma PRO shocks and if I had the Tacoma PRO springs I would have gotten 2" of lift. So I don't think it will limit the travel.
  4. Jun 1, 2017 at 7:40 PM
    Matt_DCSB
    Matt_DCSB Well-Known Member
    NM
    Does the spacer mount in the strut with the spring or is it a top plate?
    If it is a top plate spacer it moves the entire assy downward which could mean a shock would bottom out on the up stroke before hitting the bump stop.
    I believe that is what PigPen was getting at.
    Alexely999 and tcjacado like this.
  5. Jun 1, 2017 at 8:30 PM
    morgul.03
    morgul.03 Well-Known Member
    08' SSM AC TRD OR
    Did you check to see if the serial numbers are the same between the 4Runner and Tacoma front springs?
  6. Jun 1, 2017 at 9:58 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Did the guy not have the truck there of what he'd taken them off? ...otherwise my guess is there hot.
  7. Jun 2, 2017 at 3:43 AM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    Serial numbers are different and the 4Runner springs are a tad shorter.
  8. Jun 2, 2017 at 6:40 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I thought the 4Runner ran a longer coil than the Tacoma
    I'd go get the bigger coil personally, but nothing specifically wrong with putting a spacer in. It just defeats the purpose of doing a suspension lift. Do you have a spring compressor and are you doing instal yourself? If so just shell out a couple hundred on a new set of coils. Thats what happens when you buy a suspension on Craigslist Lol. I'd just chock it up to a learning experience personally.
    PS while you are at it, trade the AAL for a Dakar pack ;)
  9. Jun 2, 2017 at 8:07 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    I'd think the pro shocks are better than stock, above spacer is just fine just shim down the bump stop to the same distance it was stock, a lot of people don't do this and complain when the shock bottoms out and bends or blowers out, well no shit it will lol common sense
    58LesPaul[OP] likes this.
  10. Jun 2, 2017 at 8:24 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    See my link on my $100 lift. 2.5" Top spacer is fine...IMHO the concern in the front is the shock becoming the limiting factor under compression. I went with Wheelers bump stop.
  11. Jun 3, 2017 at 9:02 AM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    Thanks guys!
    One more question, I'm just spitballing here, I don't want to get too high on the front and I'm at 20.5" now. Is that stock height on the front? I was thinking if 20.5" was a half inch over stock, then putting those 1" spacers on would put me at about a 2 1/2" lift which I would prefer to be at 2", max. Here's the spitballing question, I have a machinist at work that could turn down those spacers maybe 1/4" if there is noting wrong with doing that. It looks like they would have to be turned down from the top. What say you guys?
  12. Jun 3, 2017 at 9:34 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Stock was 20" for me, yes
    I wouldn't want to trim down spacers.
  13. Jun 3, 2017 at 8:27 PM
    Muddinfun
    Muddinfun Well-Known Member
    Isn't that the ones from the other thread where the shocks have 2 grooves? I still like the idea of putting both shocks on the lifted grove and then put a lean spacer on the left. Or put a 1/2" lean spacer on the left, and a 1/4" lean spacer on the right.
  14. Jun 3, 2017 at 8:54 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I swapped Tacoma coils on my wife's 4Runner. The Tacoma coils were slightly longer and she got a small lift out of it.
    Not Pro models though.
  15. Jun 3, 2017 at 9:03 PM
    Pigpen
    Dan
    Northwest Montana
    Did you shim the bumps? Wheeler's bumps compress smaller than stock bumps.
  16. Jun 3, 2017 at 9:10 PM
    Pigpen
    Dan
    Northwest Montana
    Stock is 20"
  17. Jun 4, 2017 at 9:59 AM
    doorsidedown
    doorsidedown Well-Known Member
  18. Jun 5, 2017 at 6:57 AM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    Correct, I'm at 20.5 with the PRO suspension. If I add the 1" spacers will that put me at 22.5", which is 2.5" over stock?
  19. Jun 5, 2017 at 7:22 AM
    Pigpen
    Dan
    Northwest Montana
    Yes
    No idea if you'll need to shim the bump stop with that setup though.
