Got stuck for the first time.
Discussion in 'Off-Roading & Trails' started by mdc1992, Aug 21, 2015.
  1. Aug 21, 2015 at 9:11 PM
    mdc1992
    mdc1992 [OP] Well-Known Member
    Matthew
    Waco TX
    2011 Black Access Cab. 2.7L 5 Speed
    Previous 2012 White DCSB 4.0L V6
    Went Fishing with my brother under a bridge. When I drove in I stayed above the Pylons. When we left I decided to try to drive on the other side. I knew it was wet but it looked do-able. I have driven through worse. I engaged 4WD just a a precaution but left the traction control on. I started to slide a little so i gave to more gas and the traction control cut engine power and braked the slipping wheels. After It stopped I turned off the traction control and tried to go again. It started to go then just spun. So I tried backing up. That just made things worse. I tried 4 LO, Low gear just about every trick I could think of. I finally decided to quit trying before I buried it up to the axles. I called my dad and got his tundra to come pull me out.
  2. Aug 21, 2015 at 9:14 PM
    mdc1992
    Matthew
    Waco TX
    I came to the conclusion that If I had had better tires I would not have had any issues but I don't have all terrain tires and the tires on my truck now don't have the best tread depth.
  3. Aug 21, 2015 at 9:19 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    My experience is that if you get stuck in a mud hole, you can try rocking it back and forth until you get enough momentum to move forward. And that was on a 2wd truck.
    medic2230 likes this.
  4. Aug 21, 2015 at 9:21 PM
    medic2230
    Murph
    Bama! Roll Tide
    I think you should have taken the line to your left.
  5. Aug 21, 2015 at 9:23 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    4low is better in mud, 4hi is better for snow, sand etc. If you feel like you're bogging down, and back up
  6. Aug 21, 2015 at 9:33 PM
    mdc1992
    Matthew
    Waco TX
    I was trying to get over there but was a section that was wetter behind the truck out of frame and it pulled be into the ruts that were already there.
  7. Aug 21, 2015 at 9:35 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    If you go fast enough you can make it through pretty much anything. :burnrubber:
    agunday21 and medic2230 like this.
  8. Aug 21, 2015 at 9:35 PM
    mdc1992
    Matthew
    Waco TX
    I was almost out and if I had not backed up I probably could have gotten out. but when i backed up it built up mud behind the tire. So I couldn't back over it. If I had been smarter I would have remembered I had a camp shovel and dug out under the tired and gotten rocks under the bridge but It was getting late and the sun was almost down.
