Got stuck in a surprisingly deep mud hole, and now the truck is taking longer to start.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tluke81, Aug 31, 2021.
  1. Sep 1, 2021 at 6:31 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Your start description is pretty vague the amount of time to restart or time to actually crank? Kind of sounds like you are over thinking it. 1/2 a sec isn't a lot of time and fairly hard to determine.
    12TRDTacoma likes this.
  2. Sep 1, 2021 at 6:43 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Hmmm.......seems like a lesson to learn.
    Go around the mud hole when you don't know the depth.
    Starter will probably die without a bit of TLC.
    Spidicus likes this.
  3. Sep 1, 2021 at 6:46 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Might just be your battery is failing. Your starter though is on borrowed time if it got submerged in murky water.
  4. Sep 1, 2021 at 7:17 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    If the battery ground came loose then it's possible the computer reset itself and simply needs to relearn for a bit.
  5. Sep 1, 2021 at 7:24 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If your motor was hydro locked you’d know it. For the truck to start you need a couple of things, battery, starter, air, fuel.
    I’d start with the air filter first, just to make sure it’s not wet. That will choke the airflow and could give you a starting issue. Then I’d get the battery and alternator tested. Any autopart store should do it for free now adays. Then all all is good I would check the starter. Make sure you’re getting full voltage at the starter and that all cables are tight. Could be sludge built up in there but it’s moving so not a complete issue. If all
    Is well there you can check your fuel pressure. Are you part of the fuel pump recall? Perhaps it’s always started this way and you’re just paranoid?
  6. Sep 1, 2021 at 2:18 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I would go with it there is a drain in the bottom of the starter (that's what the little black hose is) Starters run pretty warm cranking and it's kind of bolted to an engine running at least 180* Or just take some sleeping pills before you go to bed.
  7. Sep 1, 2021 at 9:31 PM
    Tamaluko
    Tamaluko New Member
    Adrian
    Cement TRD
    I've driven my truck through worse.
    The starter gets filled up with water the little black rubber drain doesn't do its job and traps the water inside the contacts of the starter and corroded them. I'm gonna look for some pictures that I took when I opened it up and cleaned the contacts fixed it right up and haven't had a problem since. Until I drove it through a river and same thing happened a again.
    Here is a good (and funny) tutorial on how to rebuild/ replace the contacts in the starter. Same concept diffrent truck. Use sandpaper to clean off the corrosion on the copper parts to leave them looking shiny again!
    https://www.tacomaworld.com/threads/how-to-rebuild-the-tacoma-starter-motor.200964/
  8. Sep 2, 2021 at 7:47 AM
    clord74
    clord74 Well-Known Member
    Nashville
    Yes I do. That is the fun of it
  9. Sep 2, 2021 at 8:14 AM
    BeatnikFink
    BeatnikFink Well-Known Member
    2021 TRD Off Road
    Yep!
    Little over a decade ago my pops took his almost new FJ and plowed it into an abandoned cattle pond during rainy season. He made it about a car length in before the nose dived in and the interior flooded. It fried his electric seats but that was the extent of the damage. Had to call a friend with a winch to get un-stuck as my Durango couldn't budge him.
  10. Sep 2, 2021 at 9:33 AM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    i dont understand i hear about people doing water crossings/flood driving all the time, sure the trucks are still in motion but it seems as if the speeds are slow enough to submerge parts in the engine bay for a good amount of time. some describing water even sloshing over the hood
  11. Sep 2, 2021 at 9:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I think it takes a while for water to get into the starter casing. Usually the water crossings don't last more than 5 minutes. Whereas if the truck is stuck, it could be there for 15 minutes to half an hour. Out of the 6-7 Tacos that got swamped in my local off-road club, two had the starter go bad, a 2nd gen and a 3rd gen.
    Other things on the truck (like the A.D.D. actuator) are probably also vulnerable to prolonged submersion.
