Got the leaf Spring TSB. Here are some pics !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by khfactor, Jan 19, 2008.
  1. Jan 27, 2008 at 5:31 PM
    rick
    rick `
    yes, you qualify. it's based on the "customers complaint". and it's free
  2. Jan 27, 2008 at 7:46 PM
    mikenredding
    mikenredding Member
    2005 sr5 tacoma access cab 4x4
    I thought they were suposed to put 4 new shocks on when they do the TSB? they are doing it 4 my 2005 taco.
  3. Jan 27, 2008 at 11:02 PM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    where do you get notification of these TSB's?
  4. Jan 28, 2008 at 12:34 PM
    Buzz
    Buzz Active Member
    Customers are not notified proactively about TSBs. These notices are distributed to dealerships. They typically contain the manufacturer-recommended solution to address a common, or hard to diagnose, problem. At least in theory, you would only get the work authorized if you experience a problem and bring the vehicle in for it. There are web sites that list TSBs if you are willing to do some research.
    TSBs are different than "recalls" or "service campaigns" where a customer would be proactively contacted and asked to bring in their vehicle for a repair.
    Here is a pretty decent write up of the way it works:
    http://www.edmunds.com/ownership/service/articles/44745/article.html
    Note that dealers are not absolutely obligated to perform the service recommended by the TSB on any vehicle that they see in their shop. Some shops will just do it, while others might make you show them the problem first.
  5. Jan 28, 2008 at 7:06 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    I just took my truck in for my first of 3 free oil changes :) I asked them about the TSB for the leaf springs and they had no clue what I was talking about :eek:
  6. Jan 31, 2008 at 3:56 PM
    JackRabbit
    JackRabbit Taco Addict
    Phoenix, AZ
    07 TRD Sport SR5 Dbl Cab 4x4
    mods in sig
    You will get 4 new Bilstein shocks only if you have a NON-TRD truck as stated by the TSB.
    I have a TRD truck and just got my truck back from doing the TSB. (no new shocks) I must say I really like the ride. Rear seems stiffer but more responsive.
  7. Feb 1, 2008 at 12:52 AM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    Mine was done Tuesday, 100% better ride, corners great now, rides higher. The back end is a lot higher than the front, but it looks good. I got 4 Bilsteins, 4-leaf pack & u-bolts w/ allignment. I love it.
  8. Feb 1, 2008 at 5:07 AM
    chris L
    chris L Well-Known Member
    06 taco dbl cab , debadged 4x4 trd off road
    parts are being ordered for the suspension and the tail gate and should be in next week . my gate hasnt bent yet but they agreed to do it .
  9. Feb 1, 2008 at 5:43 AM
    khfactor
    khfactor [OP] Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    You are going about it all wrong. Do not contact the dealer first. Call 1-800-331-4331 Toyota Customer Care number and make your pitch. Play dumb and say that you experienced "bottoming out" event when you had your trucl loaded only about 350 to 400 lb. Again, playing dumb, ask the Toyota Rep if it is "normal" for the truck to BOTTOM OUT like that.
    Then you say that the manual calls for "xyz" lb loading capacity. The Rep will put you on hold and do a search. (Remember it is called, "HARSH RIDE something" in the TSB). If the Toyota Rep comes back and says thst he/she cannot find anything, suggest very diplomatically and politely that you have heard from a fellow Taco owner that she/he look up the "Harsh Ride" TSB.
    It worked for me. The Toyota Rep found it onher Data screen and asked me where I want to take the truck to get it done. She said she would contact them with a "PRE-AUTHORIZATION" for parts and labor. This is when I told her that I would take it to "ABC" Dealership. The Toyota Rep will tell you that you will get a phone call from that dealership Service Advisor for you to make an appointment.
    ONE final comment: Before you take your truck in, MEASURE (take pics also if you can) the current height and record it so you can compare it to the new height after the TSB. I measured mine from the point where the wheel touches the flat street surface crossing over the CENTER of the Hub to the underside of the Fender flare. Mine was 36-1/2" before and 37-3/4" after the TSB.
    Remember, it will settle after you have driven it for a while, so I would not worry about the INCREASED height too much. Give it some time and measure again.
    COME BACK AND POST BEFORE AND AFTER pictures from the same position...
    Good luck.:)
    beanulous128 likes this.
  10. Feb 1, 2008 at 7:08 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    ^^^ This sounds like a great way to go about it.Cut out the hassle of the dealer and go straight to the source.Nice work Kh.
  11. Feb 1, 2008 at 8:28 AM
    Coheednme13
    Coheednme13 Well-Known Member
    MattDaddy
    Elgin, SC
    11 DC TRD Sport
    Can you have this done if you have a base model taco? Or does it have to be a 4x4 or offroad edition? Thanks
  12. Feb 1, 2008 at 10:51 AM
    Flycatcher
    Flycatcher Master of the Universe
    Minnesota
    2009 Acadia (regretfully sold the Taco)
    I just called the Toyota number a couple hours ago and they won't do a thing for TSB work. They referred me to the dealer. I called a local place and they put parts on order and will do the work when they come in
  13. Feb 1, 2008 at 11:34 AM
    TacoMon
    TacoMon Northern Alliance Gynecologist
    08 DC SB TRD Sport Indigo Ink Pearl
    TRD stickers removed, oem running boards, ipod2car, Combi-cam locks for bed storage doors, Covermaster E-300 tonneau cover
    I called Toyota's c/s number and they said they don't have a # for the TSB. When I called my dealership the service writer said to bring the truck in and they would have a look at it. He specifically asked me NOT to refer to a TSB and to state that the rear suspension bottoms out under load.
    Does anyone have the actual TSB#?
    Thanks,
    TacoMon
  14. Feb 1, 2008 at 11:49 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    TSB# SU006-07 Revised
    TSB title: REAR SPRING HARSH RIDE
  15. Feb 1, 2008 at 12:58 PM
    #35
    TacoMon
    Thanks Adam, I am going to print this and keep it in my pocket for ammo should they balk at doing the upgrade.
  16. Feb 2, 2008 at 2:16 PM
    #36
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    One thing that most Taco owners who are affected by this Leaf Spring TSB does NOT know is that 1-800-331-Toyota Customer care number is staffed by non technical operators. It is a hit or miss. Sometimes you get lucky and get an operator who understand the "lingo" and look it up in the RIGHT place, and other times you get an operator who would not know a LEAF SPRING if one hit him/her in the head. So it is like a "trial" until you get it right.
    Call the 1-800-331-something number again and again until you get the satisfactory response. Write the operator's name and case # (they will give you a case # ) if your truck qualifies for the FREE TSB.
    Now go back and DIAL THAT NUMBER until you get your satisfaction !!!
    When you do get what you want, come back here and thank me and everyone else who has helped you !!! Just kiddin'
    Remember: Be very polite and diplomatic. Read my post a few notches up above. I always like to act dumb (sometimes I feel dumb and wife also thinks I am a dumba$$, but then that's another story in itself... he he .)
    Edit: Sorry I did not read your post completely where you said you get the local dealership to order parts for you... Good job !!
  17. Feb 2, 2008 at 2:24 PM
    #37
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    i was at the dealer last week and i had them pull and recalls or tsb's on my 08 and it came back with nothing. i have not experienced any bottoming out yet but i haven't reall hauled anything in the bed. maybe i will load somethings in there and see what happens.
  18. Feb 2, 2008 at 2:34 PM
    #38
    mikenredding
    mikenredding Member
    The TSB was for the 05 - 06 models, but as I understand it if you complained loud enough they would do it to the 07 model as well.
  19. Feb 2, 2008 at 3:04 PM
    #39
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Your information is OUT DATED !! The most recent one DOES include 07 !!
  20. Feb 5, 2008 at 12:21 PM
    #40
    michigantacoowner
    michigantacoowner Member
    SouthEast Michigan
    2010 DC 4 x 4
    Jason truck cap trailer two brake Excalibur remote car starter
    I called the customer service number, 1-800-331-4331, and gave them the TSB # and they took it from there. They called the factory representative for my dealership and the next day (today) the dealership called me. The service manager wanted to explain how the ride would "stiffen" and become "firmer". I think they were trying to talk me out of doing it. Anyhow, the service manager told me he would call me back with the "price list". I thought this was covered and performed at no charge. Any input on this pricing issue would be appreciated as he is supposed to be calling me back tomorrow.
