Got the new BFG TA KO2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jshill78, Nov 4, 2014.
  1. Nov 4, 2014 at 9:46 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Did they finally change the design on those or is that just a different sidewall you could order separately? My 04 has these but the sidewalls look nothing like that at all.
  2. Nov 4, 2014 at 11:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    KO or KO2 ?
  3. Nov 4, 2014 at 11:58 PM
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    I have been running E rated Duratrac 265/75x16 for 55,000 miles and no problems, i go 80% on the highway, 20% off in placed like the Nevada desert, eastern Sierras and the Mojave. I want the extra strength, side wall protection and have not had a flat yet.
    My next set which will be picking up in two weeks for my next 200 mile off road run will be E rated KO2's
  4. Nov 5, 2014 at 12:08 AM
    2004TacomaSR5
    Jon
    Montana
    Think mine are the KO's, is this the KO2 he posted? I like the looks of them better than mine.
  5. Nov 5, 2014 at 3:26 AM
    mgord
    mgord Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    Love the tires. I just got the mud and snow. 2nd set. Last one's weren't the mud and snow so looking forward to this winter.
    Yeah they are heavy for the truck but since I work out of my house it doesn't matter much and I love the way they look.
  6. Nov 5, 2014 at 6:08 AM
    jshill78
    jshill78 [OP] Member
    Jeffrey
    Raleigh, NC
    13 DC Tacoma TRD Off Road
    TRD Cat Back Exhaust
    I had a typo in the OP so I edited it. They are the LT265/75/R16. They are E rated and 10 ply (thanks spec sheet). I didn't know anything about that when I bought them. I knew I wanted a larger tire than OEM but not so large I needed a lift or that would scrub on anything. These fit the bill. True they may be overkill, but how can people who all have lifted trucks for the most part, dig on me for overkill in tires?
    They are heavier. 53.3 lbs vs the OE 38.1 lbs per tire. A 15 lb difference per wheel and a 60 lb differential for the whole truck isn't bad for unsprung weight. Especially when you consider the increase in diameter and subsequent decrease in revs/mile. I have road-side assistance so I just ditch the spare and make up the weight difference (daily, not when off road. I bought and mounted 5).
  7. Nov 5, 2014 at 7:00 AM
    Skrillah
    Skrillah New Member
    Kyle
    Indianapolis, IN
    '12 Tacoma Dbl 4x4 Off Road
    Yeah, I just got these put on my '12 Dblcab OR edition, 265/75/16 KO2. They honestly don't ride bad. They may be overkill by the spec rating but keep them aired down to 30-32 PSI and they're good to go.
    My understanding is the new KO2's are not only tougher, but will wear better and won't chunk on gravel like the original KO's did. They also have some type of special tread inside the lugs to help keep rocks out.
    Time will tell as more people pick them up and put some miles on them. Don't knock them until you try them.
  8. Nov 5, 2014 at 7:22 AM
    jshill78
    Jeffrey
    Raleigh, NC
    Lots of posts about a 255 tire. I read up some on it and I must say that's pretty interesting. A narrower tire actually increases grip. I wonder how far you can take that. I see in the second phase of the KO2 rollout there is a 235 width. Would that be too skinny to fall into the same premise? I imagine reducing the footprint via reduced width would also increase gas mileage (less friction). I think the size is 235/85/R16.
  9. Nov 5, 2014 at 7:32 AM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    What's the difference in design on the two? I didn't know you could buy KO's without the snow flake symbol?
  10. Nov 5, 2014 at 7:58 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Are those going to give us similar clearances to our 275 70 17s?
  11. Nov 5, 2014 at 8:04 AM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    I'm excited for a 35x17 ko2.. They seem like a perfect tire for all around like the KO was, only more aggressive style.
    Congrats OP!!
  12. Nov 5, 2014 at 8:25 AM
    OZ-T
    Peter North
    British Columbia
    It's basically 265/80/17
  13. Nov 5, 2014 at 8:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    HOLLY HELL!!! 53.3 lbs per tire..... problem is, its not just unsprung weight, its rotational weight which effects mpg's, acceleration and deceleration MUCH more than the same amount of static weight.
    OP unless you are doing some hard core off roading, you should of waited till they release a P or Load range C rated KO2 in your size. Ill bet your going to be 2mpg down across the board.
  14. Nov 5, 2014 at 8:43 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    If someone runs them without clearance issues I'd buy a set.
  15. Nov 5, 2014 at 8:43 AM
    #35
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    On stock 17" sport wheels of course (no spacers)
  16. Nov 5, 2014 at 8:44 AM
    #36
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
    sounds like somebody is jealous...
  17. Nov 5, 2014 at 9:33 AM
    #37
    nd4spdbh
    SoCal
    nope.
    Getting a set of Hankook Dynapro ATM RF10 in the same size as the op 265/75R16 that are all of 1.5lb heavier than the stock rugged fails going to be mounted this saturday. I didnt need an aggressive tire like the KO2, and given the shitty snow and ice performance of the orignal KO id much rather have the hankook.
    Alls im saying to the OP is, if you see a drop in MPG's its due to your expensive purchase of tires that are more than likely way overkill for your truck.
  18. Nov 5, 2014 at 9:58 AM
    #38
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    10-ply, E rated, 56lb toyos here..
    dont care..
    cuz truck..
    12taco likes this.
  19. Nov 5, 2014 at 10:34 AM
    #39
    slcnbldr
    slcnbldr Well-Known Member
    Anthony
    Northern California
    DCLB TRD Sport
    20% tint on the front windows. 8-15-13 Installed Icons front and rear with Dakars. 2012 4Runner wheels with 275/70/17 BFG T/A KO2's. Weather Tech mats front and back. Leer shell with Leer Locker and roof racks.
    I'm getting the KO2's installed today 275 70 17 I did consider the 34 10.5 17 that OZ-T mentioned but cost jumped about $100 per tire. I currently have the Hankook Dynapro ATM RF10's and have been happy with them i just wanted a change.
  20. Nov 5, 2014 at 10:45 AM
    #40
    jshill78
    Jeffrey
    Raleigh, NC
    I have a little Hyundai Elantra GT for gas mileage.
    I also increased MPG with the TRD Cat Back Exhaust by about 2, increased it again by about 2 by using no ethanol fuel only, and increased it again by about 1ish with the ECU flash. If I lose a bit because I got the tires I wanted, I'm good with that.
    AT tires are for increased off road and foul weather performance. We don't get much foul weather here in Raleigh, NC but I do enjoy hunting, fishing, and camping with my vehicle. Overkill for what I do, true. Personal satisfaction, check.
