Got the rust proofing spray done. - It's all over the body as well!
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Mar 14, 2010.
  1. Mar 14, 2010 at 4:21 PM
    ywen
    ywen [OP] Well-Known Member
    Okay so got the frame anti-corrosive treatment done at my local dealership. Picked the truck up and immediately felt the windshield was extremely hazy.. upon closer inspection, the entire truck is covered in a fine layer of that rubberish stuff they coated the frame with. Graze the hood with my finger and it'll be covered with that black crap. Went to a car wash and used the foam brush on it and it only pushed the black stuff around without getting rid of it (It is extremely sticky)..
    The only easy solution is to soak a rag with WD40 and then wipe down the body panel - It comes off real easy.
    What do you recommend I do? Is this typical when one get's an undercarriage spray job?
    Can I apply wd40 all over the paint job? Is it safe? Or is there something better?
    Thanks.
  2. Mar 14, 2010 at 4:41 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    If they put it all over your truck, they need to take it off. Send it back and don't waste the time F*ing with it.
  3. Mar 14, 2010 at 4:43 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    What he said!!! They will blame you if you mess with it.
  4. Mar 14, 2010 at 4:44 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x 999999999999999 don't even bother trying
  5. Mar 14, 2010 at 4:44 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    I would take it back. Tell them You want it fixed now.
  6. Mar 14, 2010 at 4:46 PM
    ywen
    Well I'm wondering how these sprays are usually done?
    Judging by the uniform and fine coating on the body panel (Can't even tell until I put my finger on it), I assume it was done in some sort of a paint room and the guy just went on the frames.. fine particles/mist settled all over the truck as a result.
    Short of taping the entire truck and only exposing the frame components, I don't see how this can be avoided...
    Whatever method they use to remove the tarish coating, I can probably do it more carefully myself. I would like to know the proper method of doing so.. It'll just be like waxing the truck hopefully..
  7. Mar 14, 2010 at 4:46 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    these dealerships are crooks, it seems like the salesmen set the stage while you are picking your truck out, putting little things in your ears like it's very important to do this and that, then when the finance manger grabs you he tries to seel you all of these service packages, extended warranties and on and on and on.
  8. Mar 14, 2010 at 4:49 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    I wouldn't recommend WD-40. I used it on my '67 Camaro years ago, to lubricate the convertible top hinge points. Got overspray from the WD-40 on the quarter panels. Even though I had washed the car many times after, the areas I oversprayed "fisheyed" like crazy when I had the car repainted.
    Tim Glover
  9. Mar 14, 2010 at 5:38 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    when i had my truck undercoated in the fall they first sprayed over the body of the truck with this "film" that doesnt adhere to the paint and washes off. the purpose of it was to protect against overspray. any overspray would just land on the film and once they were done they just washed the truck clean.
  10. Mar 14, 2010 at 5:44 PM
    ywen
    So I'm wondering if they sprayed this film... when you say it's able to "just wash" off, do you mean just spray the body with the high pressure rinse at the car wash or did you have to wipe it down with rag to remove the black tar?
  11. Mar 14, 2010 at 5:46 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah....They need to clean it up. No matter if it's overspray or protectant.
  12. Mar 14, 2010 at 5:49 PM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I'm probably going to need this done to my truck, as the frame is rusted but not bad enough to replace. Do you know if they do any type of pretreatment before they apply the spray, like getting all the loose rust off? I'm in agreeance with the other guys too, take it back to them and let them clean it up for you, atleast you'll get a free detail:)
  13. Mar 14, 2010 at 5:52 PM
    ywen
    Well i've already cleaned the hood and the front fenders... Gonna see how much is still left on the rest of the body panels.. should I have not done anything and brought it over dirty... In any case, I wouldn't trust them to do a better/more careful job than what I can do, I just want to be using the correct chemicals, if need be.
    For the spray, I think they just aimed and sprayed and also they dont' spray the top surface of the frame, just from the bottom and inside. They also sprayed on the factory skid plates.. They stopped at the leaf spring shackles.. I would imagine they probably removed all the wheels, but that's about it...
  14. Mar 14, 2010 at 5:55 PM
    ywen
    So no black crap on your finger when you ran it across the body surface? The coating was so fine and uniform on mine that it was indistinguishable unless you ran your finger across is and revealed what the paint looked like underneath..
  15. Mar 14, 2010 at 6:02 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    they just used a pressure washer and it came right off. they actually missed a couple spots so i pressure washed it myself once i got home and got the spots they missed
  16. Mar 14, 2010 at 6:04 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    nope no black crap
  17. Mar 14, 2010 at 6:30 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    So other than the stuff they got on your truck, how did the underbody turn out? Do they only spray the frame or all the rusty components?
    Do you know if they remove all loose rust before the application?
  18. Mar 14, 2010 at 9:42 PM
    ywen
    I don't know if they removed loose rust before spraying.
    I believe the "official" word is that they only spray the two main sections from the bottom. Cross members are not sprayed, even though my cross member looks like it received the goo.
    My frame that's inside the engine compartment shows rust at the top. They did not spray that side.
  19. Mar 15, 2010 at 1:07 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    when i had mine undercoated they did an awesome job,they sprayed everything besides the tranny,driveshaft,and exhaust. they also wirebrushed any loose surface rust,they also removed old undercoating from the year before just so this new stuff would stick that much better.
