Got this from Toyota Today.........................
Discussion in 'Off-Topic Discussion' started by surfsupl, Nov 16, 2009.
  1. Nov 16, 2009 at 10:33 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    :D What should you do if you experience pedal interference?
    1 Should the vehicle continue to accelerate rapidly after releasing the accelerator pedal, this could be an indication of floor mat interference. If this occurs, Toyota recommends you take the following actions-
    1st, if it is possible and safe to do so,pull back the floor mat and dislodge it from the accelerator pedal; then pull over and stop vehicle.
    If the floor mat cannot be dislodged,then firmly and steadily step on the brake pedal with both feet. Do NOT pump the brake pedal repeatedly as this will increase the effort required to slow the truck.
    Shift the trans gear to neutral (N) position and use the brakes to make a controlled stop at the side of the road and turn off engine.
    If unable to put the truck in (N),turn the engine off,or to ACC. This will not cause loss of steering or braking control,but the power assist to these systems will be lost.
    -If the truck is equipped w/an engine start/stop button,firmly and steadily push the button for at least 3 seconds to turn off the engine. Do NOT tap engine start/stop button.
    -If the truck is equipped w/a conventional key-ignition,turn the iginition key to the ACC position to turn off the engine. Do NOT remove the key from the ignition as this will lock the steering wheel.
    Questions.....www.toyota.com/floormats for further info
    WARNING...Read this b4 installing any type floor mat
    Only install floor mats specifically made for your modle and year truck. Check for correct model name and part # on packaging label.
    *never install mat if you are uncertain of model application
    *never install the mat upside down
    *only install the driver's floor mat in the drivers foot area
    Always properly secure the drivers floor mat using retaining hooks supplied in the bag w/the floor mats.
    Never install drivers side mat w/out all retainig hooks.
    Do not install a 2nd floor mat on top of existing mats.
    After instalation,always check the operation of accelerator,brake,and clutch(if applicable) pedals to assure the floor mat does NOT interfere w/them.
    Carefully read the warning tag attatched to the front drivers floor mat.
  2. Nov 16, 2009 at 10:55 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yes, it just goes to show that apparently you can't "idiot proof" everything. So now Toyota has to offer a replacement for your floor mats with ones that are "safer".
    That'll teach 'em. They should have just stuck all kinds of bright yellow warning labels all over them like they did to my visors, etc.. so they'd be absolved of any legal responsibility.
    OR.. (not to get too off-topic, but)
    Ford once had a problem where people couldn't get out of the Taurus in the event of an electrical fire and could die.. their 'recall fix' was to mount a small metal hammer in the glove box so passengers could smash their way to safety. That's the best!
  3. Nov 16, 2009 at 10:57 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Yeah, i got that too
  4. Nov 17, 2009 at 6:31 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    I sprayed coffee on my work monitor! Thanks! that has to be the dumbest thing I have ever heard
  5. Nov 17, 2009 at 6:49 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :rofl: :laugh:
  6. Nov 17, 2009 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    lmao!!!
  7. Nov 17, 2009 at 7:07 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I got mine yesterday too, I put it with my little yellow sticker they sent.
