Got truck back from windshield TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinklk97, Feb 11, 2008.
  1. Feb 11, 2008 at 8:28 PM
    kevinklk97
    kevinklk97 [OP] Active Member
    Clarksville TN
    2007 doublecab PreRunner
    Just wanted to update the crew on the TSB windshield.
    For those of you that are unaware of this when I was going about 75 mph and was really windy outside I would get a kazoo like sound from the windshield that was loud enough to drown out the radio, but it would only do it in spurts only when the wind hit the truck just right.
    Anyway I took the truck in Friday they looked at it and said they had to order the parts. They called this morning saying the parts were ready to be installed, 4 hours after I dropped the truck off it was ready. When I went to pick it up it didn't appear anything had even been touched the seal around the windshield was dirty, I have a decal that extends over the seal about 1/4 of an inch and it was never touched. For those of that has had this done does this sound right? I mean I thought they replaced the seal all the way around? I took it out and nothing happened so I guess its good. Just curious to how others been treated.
    Kevin
  2. Feb 11, 2008 at 8:42 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    from what i've read on the tsb, they're supposed to replace that entire seal.
  3. Feb 11, 2008 at 9:59 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Look for some clear rubber sealant like silicone. Sounds like they may have filled in the area that was causing the noise!
  4. Feb 11, 2008 at 10:01 PM
    surfsupl
    Gregg
    WestCoast
    At least they could have washed your windsheild!...Damn!
  5. Feb 12, 2008 at 3:49 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
  6. Feb 12, 2008 at 6:02 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Did you ask them exactly what they had done in 4 hours??
  7. Feb 12, 2008 at 9:37 PM
    kevinklk97
    Clarksville TN
    No I didn't ask, We were having some bad weather so when I went in I made the comment that that was aweful fast to do that and change the oil and filter. He said its not that big of a job. So far it seems fixed only time can tell though.
  8. Feb 13, 2008 at 11:35 AM
    SteelCity
    Charleston, SC
    Hell, I'd call back and ask just for the sake of curiosity.
