Got wheel bearing replaced and now vsc and abs lights come on
Discussion in 'Technical Chat' started by ICEMAN, Apr 16, 2014.
  1. Apr 16, 2014 at 5:38 AM
    ICEMAN
    ICEMAN [OP] Well-Known Member
    Eric
    Middleburg, FL
    2010 TRD Sport DC Silver 4x4
    Weather tech floormats K&N CAI fabtech 6" lift procomp 17x9 6079 Nitto Terra grapplers N Fab Nerf bars Nfab Light Bar Hella 500 FF
    Hey I hope I'm posting in the right spot.
    So two days ago I took my truck to goodyear to get a quick oil change and rotate the tires. So they call me up and say my right front wheel bearing is bad I say ok fix it ( I'm changing duty stations in four days and have a long drive) I don't want the truck breaking down. So now the steering feels better and the slight wa wa wa sound I did have is gone. But now the vsc and abs lights come on and go off intermittently. I took it back the code says debris on sensor guy says there was some grease on it and he cleaned it. I left and it comes back on. So I research it a little and the wheel speed sensor is a magnetic pick up and if I'm correct the bearing has the index marks on only one side right? Is it possible that it's in backwards. Also I did have an alignment with it could that be the problem? I've searched on here and can't find an answer.
  2. Apr 16, 2014 at 7:10 AM
    ICEMAN
    Eric
    Middleburg, FL
  3. Apr 16, 2014 at 7:25 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No it's not possible to install the sensor backwards....I don't even have those sensors hooked up lol
  4. Apr 16, 2014 at 7:26 AM
    ICEMAN
    Eric
    Middleburg, FL
    Not the sensor. The bearing. The index marks are only on one side as far as I understand. Sorry my op wasn't clear
  5. Apr 16, 2014 at 7:34 AM
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    It could be, but i cannot remember if ours use that style of if there's a interrupter ring on the cv.
    Edit:
    Nvm, it is in the bearing. They could put it on backwards but if i remember right it is really obvious which way it goes on due to the cut outs in the hub itself.
  6. Apr 16, 2014 at 9:22 AM
    ICEMAN
    Eric
    Middleburg, FL
    So maybe a bad wheel sensor?
  7. Apr 16, 2014 at 9:29 AM
    Twalt87
    Travis
    Vancouver island Bc
    OK hold on. It's coming on and off intermittent. I didn't see that.
    If it was pressed it backwards it would be on all the time.
    It could be a faulty bearing possibly or sensor. It's hard to say without looking at it
  8. Apr 16, 2014 at 9:55 AM
    ICEMAN
    Eric
    Middleburg, FL
    Yeah and the code they read out said debris on wheel sensor
    But they cleaned it off I've cleaned it off....
    So I'm not sure if they maybe messed up the wire harness the wire or the sensor
  9. Apr 16, 2014 at 10:00 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    bad electrical connection :notsure:
  10. Apr 16, 2014 at 11:24 AM
    Twalt87
    Travis
    Vancouver island Bc
    If they pressed the bearing together wrong they could have cracked the reluctor ring inside the bearing as well. Try cleaning the connections. Check the wiring for breaks or cracks
  11. Apr 16, 2014 at 11:29 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't overthink this.
    They need to diagnose and solve the problem they introduced.
  12. Apr 16, 2014 at 1:35 PM
    ICEMAN
    Eric
    Middleburg, FL
    Moose I agree with you I just want to be informed and go in there with some knowledge so if I hear a bs answer I will know it. They are going to try and fix whatever it is tomorrow.
  13. Apr 16, 2014 at 2:10 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    It's very possible that the actual bearing was not pressed in all the way..All it takes is the distance to be a micro in order for the sensor to not read.
    Happened to me on my rear wheel bearing..off by half a millimeter :mad:
  14. Apr 16, 2014 at 2:20 PM
    ICEMAN
    Eric
    Middleburg, FL
    Thanks monkey, that makes sense too I have read the tolerances for the bearing and the magnetic pick up are pretty tight
