Gotta know
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Aug 25, 2017.
  1. Aug 25, 2017 at 8:54 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Pre-lift I was at 20.25" front hub center to fender lip and 20.75" rear. Post-lift (RCD/Bilsteins at 2.5" with stock springs and HS 3 AAL with overload) I am at 22.50" and 23.50" respectively. Does that sound about where I SHOULD be at? I want the mild rake for load carrying.
  2. Aug 27, 2017 at 3:59 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Hard to say... many unknown factors.
    Call the people from whom you purchased your suspension parts from, they will have an opinion.
  3. Aug 27, 2017 at 7:32 PM
    Buckaroo1993
    Vinny
    Georgia
    @HeadStrong Off-Road
    ...Marie?
  4. Aug 28, 2017 at 4:42 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    The front does sound about right and the rear is close but a little high. There are several variables that come into play with springs, whether it is a coil spring or leaf spring. There is the overall weight of the vehicle, manufacturing tolerances of the springs themselves, and how the factory components respond to the new items added not to mention the condition of the factory components. Now with the lift just being installed the lift numbers are always greater. It does take time for everything to settle in. Depending on driving habits and use this could take a few months.
