Gotta put a alternator in my truck tomorrow any pointers to make it easier on me and her?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJsTaco, Feb 3, 2023.
  1. Feb 3, 2023 at 3:28 PM
    JJsTaco
    JJsTaco [OP] New Member
    JJ
    Tacoma 4x4 2008 shortbed king cab
    Satoshi grill, BP bumper, interior blue lights
    So I have the tools have the part not afraid to get my hands dirty, I'm here in florida and have to put this alternator in any pointers to make it easier would be delightful, shes got a 3 in lift satoshi grill BP bumper, but thing is I know I gotta take the battery and its carriage out but it was hit a while back so its bent a bit and I know its gonna be a problem,
  2. Feb 3, 2023 at 3:44 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    It only comes out one way. Unless you are super tall it helps to get up a foot or so for the reach down.
    Getting the old one out is the worst part. Going in you have gravity on your side.
    JJsTaco[OP] likes this.
  3. Feb 3, 2023 at 3:51 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Dunno, depends on the motor you have.
  4. Feb 3, 2023 at 4:04 PM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    Take it out the fender well.
    DoubleB likes this.
  5. Feb 3, 2023 at 4:13 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Where are you getting the new one from? OEM are discontinued and Napa or Autozone reman units are very suspect.
  6. Feb 3, 2023 at 4:14 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    4.0. Remove battery and battery tray
    It will give you room. Still a PITA. But an easier PITA
    JJsTaco[OP], TnShooter and Raylo like this.
  7. Feb 3, 2023 at 4:15 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    My buddy just did his on the 08 TRD, he got the bottom bolt from underneath, he was rolling around cussing for a while I guess the lower bolt was really tight. Six point socket recommended as to not round off the bolt.
  8. Feb 3, 2023 at 5:07 PM
    JJsTaco
    JJ
    No fender well. I have the bp on so that went out with the old one
  9. Feb 3, 2023 at 5:08 PM
    JJsTaco
    JJ
    Yea I'm 5'2 so Haha Haha
    wilcam47 likes this.
  10. Feb 3, 2023 at 5:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Remove the skid plate. (For access to Lower mounting bolt)
    Remove battery and tray.
    A long flex head ratchet helps.
    The lower bolt is accessible from the bottom.
    Torque spec is 32 ft/lbs for the two mounting bolts.
    I believe the bolts use a 14mm socket.
    But don’t hold me to it.
    winkel, JJsTaco[OP] and dk_crew like this.
  11. Feb 3, 2023 at 5:34 PM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Took mine out from the fender well both times. Easy.
    Might as well replace your idler pulleys and belt at the same time. Won’t take much longer.
    JJsTaco[OP] and Steves104x4 like this.
  12. Feb 4, 2023 at 5:11 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Stay away from reman alternators. Many do not replace the bearings which makes no sense.
    Here's a rebuilt Denso from rockauto.
    First line tells you all you need to know.
    Remanufacturing Process Includes:
    1. Bearing - 100% tested to OEM specifications and repacked with premium OE-standard lubricant.
    2. Stator - Insulation tested to 600 volts.
    3. Rotor - Performance and insulation tested to 600 volts.
    4. Housing - Re-tapped to OEM specifications and damage-checked for heat warping, corrosion, or improper surface alignment.
    5. Hardware - 100% stripped and replated.
    6. Rectifier - Performance tested to 300 volts.
    7. Voltage Regulator - 100% voltage tested to OEM specification.
    8. Slip Ring - Re-machined to an average of 8 microns (20 micron run-out maximum), minimizing brush wear and abrasion.
  13. Feb 4, 2023 at 8:29 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    A lot of "tested" not much rebuilding !
  14. Feb 4, 2023 at 9:08 AM
    JJsTaco
    JJ
    Yes it was a 14 and I did it!!!! Its in there!!! Proud of me!!!!! Thanks for the tips!!
    Hooligans, winkel, fixnfly and 3 others like this.
  15. Feb 4, 2023 at 9:22 AM
    TnShooter
    Deogee
    STOCK
    Good job. :thumbsup:
    Nothing like the feeling of doing it yourself successfully.
    It wasn’t too bad was it?
  16. Feb 4, 2023 at 9:23 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    guess you'll need a small step ladder;)
