GoufCustom's 1990 NA Miata Refurb Build
Discussion in 'Other Builds' started by goufcustom, Apr 25, 2012.
  1. Feb 23, 2013 at 9:21 PM
    #41
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    Took 7+ hrs today, but got it re-timed, and the new clutch back on! :D
    It just needs some paint now...
    So at 111550 miles it got:
    - New Clutch and Bearings
    - Machined Flywheel
    - New Trans Oil
    - New Reverse Light Sensor
    - New Rear Main Seal
    - New Struts and Bump Stops all around
    - New Front Main Seal and Bolt
    - New Radiator and Fluids
    - New Radiator Hoses and Clamps
    - New Water Pump
    - New Camshaft Position Sensor Seal
    - New Camshaft Front Seals
    - New Valve Cover Gasket
    - New Engine Oil and Filter
    - New Timing Belt and Tensioner and Idler
    - New Alternator Belt
    - New Power Steering Belt
    - New Crankshaft Bolt and Key
    - Steering Wheel Cover
    At ~109000 if got the following:
    - New Wheels
    - New Tires
    - New Lug Nuts
    At ~104000 it got the following:
    - New Shifter Boots
    - New Spark Plugs
    - New Brake Pads
    - Brake Line Flush
    - New Diff Fluid
    - Catch Can
    - New Engine Oil, Radiator and Trans Fluids
    - New Soft Top
    - New Spark Plug Wires
    - New Head Lights
    - New PCV Valve
    - New Thermostat
    - New Wheel Bearing (Front Pass)
    - New Tie Rod Ends
    - New Lower Ball Joints
    - New Energy Suspension Bushings
    - New Eccentric Bolts
    - Some New Fuses
    - New Battery
    - New Fuel Filter
    - New Air Filter
    - New Radio
    - New Shift Knob
    - New Shift Outer Fabric Boot (home made)
  2. Jul 21, 2013 at 12:14 PM
    #42
    goufcustom
    MD
    All my links broke because I started to organize my PhotoBucket into folders...
    SOLD August 2013
