GPS mount perfect, complicated
Discussion in '1st Gen. Tacomas (1995-2004)' started by amkaos, Feb 25, 2016.
  1. Feb 25, 2016 at 10:53 AM
    amkaos
    amkaos [OP] Well-Known Member
    Hi
    I finally found my perfect GPS mount..
    It's complicated, take notes ..got a 10" mini usb cord and a rubber band.. I hope my pics are clear...
    Band goes around ashtray and gps port /cord... This attachment holds really well.. And no dangling things..or suction cups falling off.. BTW, my USB charger supports 2 x 2.1 amp
  2. Feb 25, 2016 at 11:25 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Looks good. I need something like that too. It would be nice if you would post back after 100 miles of off-roading and let us know how sturdy that installation is. Also, it looks like the installation could use something to keep the top of the display from rocking against the radio's bezel, or from falling forward into the shifter altogether.
  3. Feb 25, 2016 at 11:33 AM
    amkaos
    I tested the setup for several hundred miles in real time use... Just drove normally... Unit never got out of balance or shifted atall.. The unit perches itself w/out the rubber band pretty well except hard right turns... The rubber band is solid, really.. It doesn't rock, shift etc... Nothing.. Plus the band is completely hidden
  4. Feb 25, 2016 at 1:24 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I remember those things. I used them all the time in new towns I'd travel to. Sadly, technology is slowly making them obsolete. You can basically say what you're looking for into your smart phone and it'll show you the way. My only gripe with those units is after a few updates, you've paid more than you did for the unit itself.
  5. Feb 25, 2016 at 1:36 PM
    amkaos
    Maybe but idk bout all that really ... Gps so cheap... And they have life time maps.... Screen bigger, more info,,, on and on
    But phones are fine too
  6. Feb 25, 2016 at 4:43 PM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    So I just spent the last few days trying to find a perfect setup for a phone mount (mainly to use as gps). I wanted to make sure it wouldn't cover up anything important like the cd player or the hvac controls and was planning on trying to get a mount to attach where the passenger airback switch is (on my 02 it's just a blank slot). But then I found this:
    Made by Panavise part #75137-999. It's kinda spendy for a metal bracket, but for $30 I wasn't going to try and make my own. It attaches with screws to the cd player bracket screws so it's super solid. I then bought a 17mm AMPS adapter plate with a 17mm ball on it:
    http://www.amazon.com/gp/product/B002ACP2FY
    That will then in turn attach to a samsung wireless charging mount:
    http://www.amazon.com/gp/product/B00NT5LDJ0
    Should be a really nice setup that doesn't block anything and is super sturdy. Jump in my truck, snap my phone into the mount and off i go. It'll charge wirelessly while streaming music via bluetooth. All the pieces should arrive early next week and I was going to post once I have it all setup.
    djcharlee likes this.
  7. Feb 25, 2016 at 7:21 PM
    djcharlee
    djcharlee RETIRED SSGT OF MARINES
    Carlos
    Chula Vista, CA
    2020 Double Cab TRD OR
    Pro Comp Leveling Spacer 17" Icon Wheels Falken Wildpeak AT3W 285/70R17
    ^ nice... can't wait to see it all installed. Will be nice for when i upgrade my Note3 to a Samsung S7 or Note7
  8. Feb 25, 2016 at 7:27 PM
    BiNiaRiS
    Portland, OR
    Yeah, I couldn't believe that there was almost no talk about this piece on here. It's a bit spendy but it's something most of us use a ton in our trucks. I have a note 5 now but might be switching to the s7 edge but it'll fit in this setup just the same.
  9. Feb 29, 2016 at 6:06 PM
    BiNiaRiS
    Portland, OR
    Parts came in today and I'm super happy. Easy to install and it's really steady and solid. The wireless charging seems to be just powerful enough that I can stream music via bluetooth with the screen on constantly and the battery will stay put which is all I usually care about. If i'm really in need of a bit of a charge I'll just connect it directly do the fast charge outlet and get topped off. Pic here:
    http://imgur.com/a/M4K2x
  10. Feb 29, 2016 at 6:53 PM
    djcharlee
    Carlos
    Chula Vista, CA
    Looks great. added all the parts to my Amazon wish list. :)
  11. Feb 29, 2016 at 7:48 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I made a custom dock for my iPhone where the airbag switch goes. I used a swivel from proclip and 3d printed the rest. I'll try to get some pictures of it.
