GPS mounted @ Garage dr hlder
Discussion in 'Audio & Video' started by WV_Tacoma, Jul 20, 2009.
  1. Jul 20, 2009 at 12:01 AM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Anyone try to permeatly mount a GPS unit in the Over head Garage door holder?
    I was thinking about getting a thin GPS and mounting it to the door...When you need it you just open the door, flips down and off you go...Would keep someone from seeing it on the window and or having to remove it ever time you don't want your glass broken.......
    There may not be enough built in GPS ant signal in this location....
    Also the angle up there may be a problem...
    Thoughts????
  2. Jul 20, 2009 at 12:03 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Interesting...
    You'd probably have to test a lot of different sizes.
    Good idea though.
  3. Jul 20, 2009 at 7:11 PM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Maybe a plug-in patch antenna could make it work OK. Might be hard to read from that angle, though.
  4. Jul 20, 2009 at 7:25 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    i know mine will just sit up in there but it wont close
