Grabber AT/X or Duratracs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Jan 5, 2020.
  1. Jan 7, 2020 at 8:56 AM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    I've researched them for a few hours they seem to be pretty good tires. Idk where you're getting your info from
    Ritchie likes this.
  2. Jan 7, 2020 at 9:26 AM
    WhiteTruckMafia
    WhiteTruckMafia Well-Known Member
    TN
    19 TRD PRO
    Guys that actually wheel and have ran them. Such as guys on TW that aren’t just chasing the cheap tire options that look “cool”. Guys that wouldn’t buy a Walmart Pro grill. They’re in here believe it or not.
  3. Jan 7, 2020 at 9:29 AM
    WhiteTruckMafia
    TN
    19 TRD PRO
    We’re out here man! Lol
  4. Jan 7, 2020 at 9:32 AM
    WhiteTruckMafia
    TN
    19 TRD PRO
  5. Jan 7, 2020 at 11:38 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    Every tire I’ve looked at has similar problems every once in awhile. Tires are mass produced and there’s gonna be some dud tires with every brand. I’m just looking for a good tire that will work on my dd and some off-roading that doesn’t cost a fortune and has good reviews. The wildpeak seemed to cover all that and I’ve heard great things about them.
    Ritchie and Das it mang like this.
  6. Jan 7, 2020 at 11:43 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Go with them homie. Third gen owners complain about anything and everything anyways, so tread lightly with what they say. (pun intended) Like I said my E rated wildpeaks have done well, and showing little to no wear at 12k miles since I bought them. Wheeled plenty of times with them and they've held up well. No issues with vibrating on highway or anything. Go with the majority vote versus minority complaints
    GQ7227, Fuergrissa and Ritchie like this.
  7. Jan 7, 2020 at 11:52 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    Good man, I appreciate the helpful feedback
    Das it mang[QUOTED] likes this.
  8. Jan 7, 2020 at 4:05 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    You'll like the Falkens.
    I've aired them down to 10 psi without issues.
  9. Jan 7, 2020 at 4:10 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    Ive also been thinking about the Grabber ATX. Hard to choose
  10. Jan 17, 2020 at 11:14 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I took a set 265/75-16 load range C Duratracs off my Taco today. Over 46,000 miles and 6/32" tread remaining. Been through heavy snow, compact snow and ice, mud, rocks, washboard gravel, freeway, two lane highway, city, you name it and they saw it. No uneven wear. No vibrations. No need to rebalance. No shimmy. No problems whatsoever. I replaced them with another set of Duratracs. Best AT tire i've owned in 40 years of driving.
    JJ04TACO and GQ7227 like this.
  11. Jan 18, 2020 at 4:08 AM
    ECO Lander
    ECO Lander Well-Known Member
    I have traditionally used the cooper at3 and it is a solid tire with good wear and quit on the road. I have had two sets on my Tacoma and they have been descent off road. Take care of hen and they will easily do 40k. However, with recently moving near the mountains I wanted something more aggressive and tried the Faulkin Wildpeaks and I have been impressed. They are just as quiet on the road and great in snow/mud. I only have 5k but they are warring nicely.
  12. Jan 18, 2020 at 5:19 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Some more aggresive yet road friendly options:
    Goodyear Trailrunner AT
    Cooper AT3
    Firestone Destination AT or AT2 (What I just bought, great so far)
    Yokohoma Geolandar GO15
    Toyo Open Country AT2
    Cooper Discoverer RTX
    Imo, Falkens seem cheap to me. Not many people I know speak well of them.
    GQ7227 likes this.
  13. Jan 18, 2020 at 5:21 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i've had size 15 duratracs for about 21k miles, they are due for another rotation at DT so I will have them measure the tread to see where they are at.
    i was very much hoping to get many more miles than you got on yours! ... because they aint cheap and i have a shitton of 'maintenance' expenditures for this truck this year just as i did last year, major costly maintenance that should only be a once in a decade type of expenditure
    with my stock wheels the balancing on them is very complicated the DT guys told me
    what psi do/did you keep yours at?
  14. Jan 18, 2020 at 7:48 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    4th maybe 5th set of Duratracs here. You're supposed to balance and rotate every tire fairly often. As you drive, hit bumps and they wear, they will slowly change and go out of balance. Balancing a tire is not that complicated as the machines used to do it are very common and capable. Just place the correct weight where it tells you to.
  15. Jan 19, 2020 at 1:40 AM
    #35
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    That is pretty good mileage for a MT. The Duratrac is essentially a MT/AT hybrid tire. And they are a decent snow tire so the compound must be fairly soft. If you live in a warm dry place they might last 60,000 miles. If you have four seasons with real winters then you might have to chuck them with far fewer miles. The best of any tire is the first 50% of the tread.
    They chalked at 25 lbs or so. Didn't like how they felt at 25 so ran around 32.
    Edit - I rotated every 5K to 7K. Never had to rebalance. Wear was very even with no unevenness.
  16. Jan 20, 2020 at 6:10 PM
    #36
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    I had Duratracs and they were great off road. I could never get them balanced. Numerous trips to different tire stores and no luck. I pulled them off and got some KM3’s and love those.
