Gravel Road Tire Pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by POW HOUND, Aug 23, 2021.
  1. Aug 23, 2021 at 11:50 AM
    POW HOUND
    POW HOUND [OP] No friends on a powder day
    Idaho
    2020 Manual Trans Silver Sky
    When I search all I find is people arguing about 2-3 psi difference on-road tire pressures haha, how low are you guys going on those long washboarded gravel roads? I did a test down to 20 psi but I was getting mixed signals between two cheap guages so I can't say for sure what I was at. Doesn't seem to be a lot of sidewall protection on the stock Goodyears
  2. Aug 23, 2021 at 11:55 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    You just need to air down when you get to very loose gravel, rocks, sand, snow at lower speeds.
    Junkhead likes this.
  3. Aug 23, 2021 at 12:01 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    my truck had like 30 psi when i bought it, and thats where it stayed until i got it serviced again earlier this summer and they bumped it up to 40 psi.
    i dont seek out rock crawling, but driving through the mountains in colorado leads me to some bumpy stuff. i have a compressor and air down/up stuff, but never use it. still smoother than my old expedition
    POW HOUND[OP] likes this.
  4. Aug 23, 2021 at 12:07 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    20-25psi for air down scenarios. Anything less you may lose the bead.
  5. Aug 23, 2021 at 12:14 PM
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    I travel a lot of gravel roads like you mention. I have E load 265/75R16 tires that I air down to between 22-25lbs. I find this smooths out the bumps some, making a little more enjoyable travel. I decided to switch from the stock Goodyears before 10,000 miles because I didn't trust the sidewalls with the roads I frequented. Of course a big lead tire weight went straight through the tread of one of my E loads on I95 with only about 700 miles on it. Go figure.
    POW HOUND[QUOTED][OP] likes this.
  6. Aug 23, 2021 at 12:44 PM
    POW HOUND
    Idaho
    I'm not looking as much for traction, just to rattle the truck less on the washboarded and rough roads. I air down just because of the distance I travel to fishing/camping spots without paved roads on weekends.
    Stocklocker and stevesnj[QUOTED] like this.
  7. Aug 23, 2021 at 12:46 PM
    POW HOUND
    Idaho
    Awesome input thank you, I agree on the Goodyears sidewall. Doesn't seem like the worst but not a lot of protection if you air down and ride on them for distance.
  8. Aug 23, 2021 at 12:49 PM
    POW HOUND
    Idaho
    20 was what I was thinking for a lowest number, thanks for the confirmation!
    2021SR5V64WD likes this.
  9. Aug 23, 2021 at 12:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For this scenario, I would go 20 for the sake of comfort. Don't be scared to go lower though. You're at the greatest chance of rolling a bead when you're <12 psi and also making abrupt turns, ripping donuts, etc. Rolling a bead is harder than you might think. I say this because if you let out a little more pressure than intended, your truck won't implode.
  10. Aug 23, 2021 at 12:53 PM
    corrado-correr
    corrado-correr Well-Known Member
    Royal Oak, MI
    2021 TRD Sport
    32psi warm works for me on the gravel/washboard. i like to dive fast.
  11. Aug 23, 2021 at 12:55 PM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    It's a balance between low enough to provide comfort, but not low enough to drag sidewall or overheat. Make sure there's no dirt pattern on the sidewall past the side lugs from it touching the ground, and stop after a bit to make sure the tires aren't overheating. I had them get pretty hot at 20psi doing 40-45mph gravel roads with potholes. Other than that, have fun. Just keep using the same gauge so you know what your numbers mean.
    That being said, 20psi is my lowest. I had sidewall touching ground on some rocks at 17. (265/65/17 at the time). I would go lower if I ever got caught in deep sand and needed more flotation though.
  12. Aug 23, 2021 at 12:56 PM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    15 psi seems about right, I have run that at high speed on gravel with good results. If the bed is empty I would consider going down more in the rear.
  13. Aug 23, 2021 at 1:01 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Remember on Tacomaworld nothing is agreed upon and everything should be argued over. :cool:
    02Duck, mello03, tonered and 6 others like this.
  14. Aug 23, 2021 at 1:01 PM
    Mods2Travel
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Just re-read the original post. If you're running stock tires with no sidewall lugs...I might stay in the upper 20's. I'm definitely rolling the sidwall lugs onto the ground at 20. I aired down someones rental Taco to 26 for some rocky trails in Colorado and there were definitely marks on the sidewalls after.
  15. Aug 23, 2021 at 1:16 PM
    POW HOUND
    Idaho
    Gotcha, yeah the stock goodyears have sidewall lugs but nothing gnarly or anything. Thanks for the input, it makes a lot of sense and I appreciate it!
  16. Aug 23, 2021 at 1:24 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'm going to go out on a limb and say that tire pressure is WAY too high. Assuming you don't have crazy loading (weight) on your truck.
    Sharpish, whatstcp and jasmits1 like this.
  17. Aug 23, 2021 at 1:31 PM
    mrtonyd
    Tony
    Colorado
    i agree. was a little disappointed when i got my truck back with that psi. i run a little over 30 now and will drop a bit when cold weather comes around
    Bertw192[QUOTED] likes this.
  18. Aug 23, 2021 at 1:33 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    Seven....
  19. Aug 23, 2021 at 1:34 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Air down for gravel roads? What sort of craziness is this? I grew up in an area where a majority of the country roads were gravel and no one ever aired down for them. Same for snow covered roads. I guess if have lots of spare time, go ahead. I do agree that E-load tires ride like a dump truck when aired up.
    02Duck, stevesnj, ConantTaco and 2 others like this.
  20. Aug 23, 2021 at 1:38 PM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    I've never bothered for gravel roads. I've spent plenty of time driving around on gravel and washboard at 20psi if I was aired down for something more technical and never found it to make enough difference to be worth the hassle. I run between like 33 and 35 on the street(edit: on E-range KO2s).
    In fact, on the stock suspension(for the Off Road at least) really the biggest issue with gravel road comfort is that the suspension is too soft and allows for way too much uncontrolled body movement. Nasty and even moderate washboard seemed to throw it into some kind of weird resonance where the shocks completely fail to dampen the springs. Softening the system further by airing down seemed to make it worse if anything.
    The only way really to smooth out washboard is to follow the sage advice of Jeremy Clarkson:
    02Duck, POW HOUND[OP] and gudujarlson like this.
