Gravel Road Tire Pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by POW HOUND, Aug 23, 2021.
  1. Aug 23, 2021 at 1:43 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I tend to agree that speed lets you float over washboards and other small imperfections. I tend to drive 50-60 (100+ when I was young and dumb) on gravel roads unless they are in really bad shape or visibility is bad.
    Junkhead likes this.
  2. Aug 23, 2021 at 1:55 PM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    Same, depending. I live in Oregon so a lot of our roads are tight but the slower the traffic the closer spaced the corrugation(cuz physics). I find that almost any road has a speed that gets you on top of the washboard at a reasonable speed, when you find it it's almost the same lovely feeling as when you get a boat up on plane. I mean I've taken some overland trips deep into BC where they have big, wide and straight gravel highways where 70 is the flow of traffic. Meanwhile I know some roads where 30 gets you there.
    Either way, the only way to fix getting your teeth rattled out on washboard is more speed.
    Junkhead and gudujarlson[QUOTED] like this.
  3. Aug 23, 2021 at 2:03 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I kinda want to put this as my sig... :rofl:
    Junkhead, Bertw192 and tonered like this.
  4. Aug 23, 2021 at 2:06 PM
    Sterling_vH111
    Sterling
    socal
    But I usually run 20psi offroad out in the desert, speeds up to 80mph.
    About 16 if I think I'm going to encounter some sand or soft stuff.
    In the sand dunes, I've gone to 10psi rear and 12psi front -- 2wd -- doing donuts, drifting turns, higher speeds of around 45-50mph -- never blown a bead with my e-load 33's.
    POW HOUND[OP] likes this.
  5. Aug 23, 2021 at 2:59 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Good reference!
    How to Air Down Off-Road Tires for Overlanding
    by Bryan Rogala
    January 28, 2021
    Overlanding upgrades often include expensive add-ons like lockers, a winch, or a new suspension. But there is a simple upgrade that will improve your vehicle’s traction, and it doesn’t have to cost a penny. Try airing down your tires.
    Traction starts and ends at your tires and improves your vehicle’s off-road capability immensely. If your tires don’t have traction then it doesn’t matter how advanced your vehicle’s traction control system is or how much money you’ve dumped into other modifications. Airing down, or letting air out of your tires to reduce the pressure, increases a tire’s contact patch on the ground. Under the right conditions, airing down provides more traction and a smoother ride.
    Read on to learn how to gauge tire pressure, the different methods for airing down, tools to make it easy, and how to air back up when you hit the pavement.
    How Low Can You Go? Airing Down Your Tires
    First, let’s talk about air pressure in general. There’s no hard and fast rule on what pressure you should air down to, and most tire manufacturers won’t give recommendations for liability reasons. Choosing how much air to let out of your tires will largely depend on your specific vehicle and tires, what street pressure you run, and your driving preferences. In general, lighter vehicles, like a Subaru Forester or Jeep Wrangler, can run lower air pressures off-road than a larger vehicle.
    The best guide I’ve found is from Jonathan Hanson, a writer and adventurer who co-founded Overland Expo and Overland Journal. As a rough starting place, Hanson recommends dropping pressure by 25% for general off-road driving on rough dirt roads, washboard. and moderate trails, 30-35% for traction on slick-rock and difficult trails, and up to 50% for surfaces like very soft sand.
    Let’s use my 06 Power Wagon as an example. I run about 44 PSI in the front tires and 54 PSI in the rear on the street, and going by the guide above I should be running around 30 PSI in the front and 40 PSI in the rear on most easy off-road terrain. I can go as low as 22 PSI upfront for deep sand. Remember, that’s just a starting point: figuring out the best pressure for your rig will take some testing to see what works best.
    Tire Choice
    Before diving into the nitty-gritty on how to air down, let’s talk about tire choice. Tires are the most important piece of the traction puzzle, and the tires you put on your vehicle can make the difference in how far down the dirt road you venture.
    All-terrain tires work best for overlanding, offering a durable tread compound and burly sidewalls. These elements help protect the tires from punctures and other damage while driving off-pavement and also makes them better suited to airing down. When you reduce the pressure in your tires, the sidewalls flex, providing more tread in contact with the ground. Stiffer, stronger sidewalls allow you to air the tire down more with less worry about damage.
    The Toyo’s Open Country A/T III, which I run on my truck, or BF Goodrich’s All Terrain T/A K02, provides an upgrade in off-road traction compared to the stock all-season tires that come on most crossovers, SUVs, and trucks. Thanks to a more aggressive tread pattern that has more bite, these tires perform well in loose dirt and rocks. Despite being more aggressive, they still work very well on pavement and remain quiet on the highway.
    Three Methods for Airing Down
    The Cheap Method
    Tire gauges, like the small, pen-shaped devices that are available at most gas stations, will measure PSI and let air pressure out of your tires at a low cost. To use the tire gauge, depress the valve core and monitor the pressure gauge until you let the desired amount of air out of your tire, and repeat the process for each tire. You can also use a stick or other slim object like a pen if you’re in a bind, being careful not to let too much air out.
    The biggest drawback of the tire gauge method is that, depending on your tire pressure, it takes a long time and you’ll only be able to deflate one tire at a time. There are several tools to consider to make it easier on yourself.
    The Fast and Precise Method
    To reduce time spent airing down, many overlanders use ARB’s E-Z Deflator. This tool removes the valve core (the mechanism that prevents air from escaping the tire) and lets you decrease pressure from your tire faster, saving you a ton of time at the trailhead. While you can remove the valve core yourself, you risk losing the valve core and ending up with a flat tire. The E-Z Deflator encases the valve core inside of it, ensuring you won’t lose it, and uses a built-in pressure gauge so that you won’t miss your mark when airing down. Unfortunately, using this method means you still only deflate one tire at a time.
    The Automatic Method
    Use automatic tire deflators to let the air out of more than one tire at once. Automatic tire deflators screw onto your tire’s valve stem and automatically let the air out of the tire until you reach your target pressure. First, you need need to set up your target tire pressure manually and then simply screw them on to your valve stems and let the tire deflators take the air out for you. When your tires reach the desired pressure, the deflators shut off and stop letting air out. This means you’re free to do other tasks and that you won’t have to worry about checking tire gauges. Here’s a great video on how to use automatic tire deflators. While at a higher price point this set from Staun has been proven over the years and is highly recommended.
    If you want to make airing down even easier, consider another tool called an Indeflate. It’s a simple device with two air hoses that automatically equalizes the pressure in two tires and allows you to deflate or inflate two tires at once. It still takes the same amount of time that it would for your compressor to inflate two tires, but this tool will remove one step and pair down your airing down/up process even more.
    Airing Back Up
    Airing down provides a much more comfortable ride off road and gives you better traction, but running low pressure on the pavement is unsafe and robs you of fuel economy. Underinflated tires heat up on the pavement, especially at highway speeds, and are subject to blowouts and failures, so you must fill your tires back up when you leave the dirt. Driving slowly to a gas station with an air compressor works in a pinch, but you’re better off carrying an air compressor in your vehicle.
    There are many portable air compressors on the market designed for automotive use. I recommend a high-quality compressor that connects to your vehicle’s battery for maximum filling capacity. For filling up larger off-road tires you should look at one from VIAIR or ARB – like VIAIR’s excellent 400P. Avoid buying one of the small compressors that plug into your car’s 12v outlet; they just don’t have the power to fill up tires quickly, and once you realize how long it takes it’s unlikely you’ll ever air down again.
    When you choose an air compressor, pay attention to the CFM (cubic feet per minute) rating and duty cycle. The CFM number refers to how much volume the compressor can move, and the duty cycle refers to how long the compressor can run before needing to shut down. I’ve used VIAIR’s 400P Automatic for years with great success, and it will fill one of my truck’s 35×12.5in tires from 15-30PSI in 2 minutes and 45 seconds.
    Make Airing Down Easy and You’ll Do it More
    After swapping on a set of all-terrain tires, airing down provides the biggest performance boost you can give your rig. The time it takes to air down prevents many people from skipping this step, despite the many benefits. With that in mind, make airing down easy and you’ll be more likely to do it. A set of automatic tire deflators and a good air compressor will accomplish that goal.
    NWBoon likes this.
  6. Aug 23, 2021 at 3:06 PM
    OmahTako
    SoCal
  7. Aug 23, 2021 at 3:14 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    The Goodyear side wall is the worst I've ever seen. In 17k km, I had 3 nails through the side walls. All happened on the highway. I finally got sick of it and got some wild peak atw3s. Never had another issue.
    Junkhead, POW HOUND[OP] and jasmits1 like this.
  8. Aug 23, 2021 at 3:19 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    15-18 ive never lost a bead hauling at 80+ on washboard.
    10 on the real stuff
    Junkhead, POW HOUND[OP] and kfatt like this.
  9. Aug 23, 2021 at 3:29 PM
    kfatt
    kfatt Active Member
    If I'm bothering to air down, I'm going 20 or less. The difference between 12, 16, and 20 is huge.
  10. Aug 23, 2021 at 3:49 PM
    jasmits1
    I got 6(SIX!) flats on the stock Goodyears over the course of one summer of frequent but mildish trail use(I say ish because we're talking non-technical terrain as I have a beater Land Rover and my truck was still new but lots of miles of very rough and rocky overland type stuff). Got to the point that I'd go "guess what?" on the radio and my buddies would be like "You got a flat!". All mine were at least on the trail. Between two sets of KO2s on my Taco and one set on the 2nd Gen 4Runner it replaced I've had one flat from a pretty nasty screw, and one from the same on the AT3s on my Rover.
    MaverickT883[QUOTED] likes this.
  11. Aug 23, 2021 at 3:59 PM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Why E rated tires on such a light truck???
  12. Aug 23, 2021 at 4:02 PM
    gudujarlson
    Minnesota
    Because it’s basically the only option for 33” tall skinny mud terrains. I bought a second set of rims for them so I could commute on p-rated tires but then COVID happened and I work from home so the M/Ts have remained on the truck.
  13. Aug 23, 2021 at 4:08 PM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    I've never aired down for gravel. 32psi on the Tacoma for forest service roads, generally keep it under 30mph and it's fine. 80psi in the superdirty out in the oil fields, those roads you can go 75mph and it's perfectly smooth.
    Some speed does help you "float" over washboard and smooth it out a bit, just beware that you won't have much braking when you're doing that.
    stevesnj and POW HOUND[OP] like this.
  14. Aug 23, 2021 at 4:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was surprised at the effort a person put into getting a bead to unseat at 6psi. He had to slide it hard on packed gravel.
    Don't worry about anything above 15 and normal, sane wheeling.
    POW HOUND[QUOTED][OP] likes this.
  15. Aug 23, 2021 at 4:09 PM
    #35
    gudujarlson
    Minnesota
    80psi? Is that a typo?
  16. Aug 23, 2021 at 4:10 PM
    #36
    jasmits1
    Honestly it really limits your selection for any width of 33" AT or MT if you insist on staying away from Es.
    Ugh I really wanted to run tall skinnies after putting my lift on but I damaged a sidewall on my old 265/75s the week before it arrived and every 255/85 tire(as in all 4 options lmao) was on backorder for months. Tire was holding air but really sketching me out and I didn't feel safe driving on it for that long so went to 285s.
  17. Aug 23, 2021 at 4:17 PM
    #37
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Airing down is for jeepers to get out of my way when I pass by them at the trailheads:bananadance::mudding:
    Just kidding, I just don’t see doing it when I’m only driving in less than 10 miles and the roads are not that bad.
  18. Aug 23, 2021 at 4:49 PM
    #38
    POW HOUND
    POW HOUND [OP] No friends on a powder day
    Idaho
    2020 Manual Trans Silver Sky
    I grew up in rural wyo, I'm well aware why you're confused why someone would air down but it's different when you're not on the frequently graded roads. I did a 140 mile round trip ride on a washboarded road and you probably still wouldn't believe me when I say 10 minuets of airing down is worth less teeth rattling
  19. Aug 23, 2021 at 4:51 PM
    #39
    POW HOUND
    Idaho
    Sweet I'll check out the wild peaks, thanks
  20. Aug 23, 2021 at 4:54 PM
    #40
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Thatbassguy likes this.
