GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. Nov 9, 2017 at 6:31 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    And they are super cheap.. Get some for peace of mind.
    robssol likes this.
  2. Nov 9, 2017 at 7:29 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Better safe than sorry. I've had a complete brake failure (Ford product) not fun!
    Agree!
  3. Nov 9, 2017 at 7:45 AM
    robssol
    Rob
    S. Wisconsin
    Keep your head down. Good luck.
    I've never understood the whole reapply for the job you already have thing. Company making employees jump through hoops because they can. Seems kinda petty to me.
  4. Nov 9, 2017 at 3:04 PM
    StainlessSteelRatt
    StainlessSteelRatt Well-Known Member
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Icon, SPC, OME Dakar, Mobtown
    What am I looking for then for a third gen (is there a length or type or brand I'm looking for)? Also, what's the best way to correct for "Taco lean"?
    It's my first lift and I'm trying to do it right.
    And how the HELL do I multiquote??? Can you quote a post with multiquotes? :anonymous:
  5. Nov 9, 2017 at 3:42 PM
    Axinex
    Axinex Desert Rat
    Sam
    Phoenix, AZ
    2021 Army Green Tacoma SR5
    Bone stock. Pls mod me.
    In. 5 of 5. TGIF.
    Basically the same setup I'm saving my pocket change for. I concur on the extended brake lines though. Spend a few bucks and get the braided ones. Brakes just feel more responsive with them IMO.
  6. Nov 9, 2017 at 4:02 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Select all posts that you want to quote by hitting multi.
    Then at the bottom>
  7. Nov 9, 2017 at 4:29 PM
    robssol
    Rob
    S. Wisconsin
    The button in the lower right hand that says "Multi-Quote+" right next to "Quote"
    There is a vendor on here that sells braided brake lines. I can't remember the name. Found it after an exhaustive search! OCTaco sells steel braided brake lines.
    3rd gens have Taco lean?
    :thumbsup:
  8. Nov 9, 2017 at 5:24 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    AFAIK "Taco lean" is the very slight listing to the driver's side, due to the weight of the gas tank. I think it's a 1/4" shim or something folks put in to correct it? I thought I saw nylon ones talked about somewhere here, they were pretty highly thought of if I remember correctly.
    robssol[QUOTED] likes this.
  9. Nov 9, 2017 at 5:37 PM
    robssol
    Rob
    S. Wisconsin
    Mine has a slight list to port. I thought Toyota corrected that particular problem.
  10. Nov 9, 2017 at 5:47 PM
    Matic
    Tricky Dick
    Easley, SC
    Far as I know, the configuration is same as always.
    Battery, gas and driver on the same side.
    I run both .25 spacers on a new lift upfront and when it starts to droop I just take the passenger side out.
    StainlessSteelRatt likes this.
  11. Nov 9, 2017 at 8:51 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    So you just need a spacer on the driver's side front to correct the lean?
    robssol and Matic[QUOTED] like this.
  12. Nov 9, 2017 at 9:12 PM
    Matic
    Tricky Dick
    Easley, SC
    Correct.
    I think I've only ran into one thread concerning taco lean on a 3rd gen.
    Edit: have you measured yours with factory suspension?
  13. Nov 9, 2017 at 9:20 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Nope, not yet.
    I have to wait 'til maybe the end of the month to get started on this, there's a re-org here at work right now and I want to make sure the dust's settled first...
    Matic[QUOTED] likes this.
  14. Nov 9, 2017 at 11:24 PM
    santas212
    Georgetown, CT
    I have never parked somewhere that’s level enough for me to notice a 1/4” lean.
  15. Nov 9, 2017 at 11:31 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Yeah, NO mall is perfectly flat.... :p
    robssol and santas212[QUOTED] like this.
  16. Nov 9, 2017 at 11:35 PM
    Matic
    Tricky Dick
    Easley, SC
    I think the 1st gens were the worst. I'm on my 2nd set of ome 881 coils and both needed them.
    The rear is negligible with only about a 1/4 in drop.
    Also, I usually always wheel alone so the passenger side never gets any weight which makes it worse.
  17. Nov 10, 2017 at 1:37 AM
    Jthizz2006
    Jthizz2006 Well-Known Member
    Jesse
    16 black tacoma DCSB SR5 4x2
    So i have a 25k service on my 3rd gen later this morning. I also noted to them that the tsb-0053-16 for the howling/whistling noise i have has not been resolved. Hoping they inspect the window seals as its been windy down in the central valley and that noise comes at about 60mph.
  18. Nov 10, 2017 at 1:51 AM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Man, I tell ya - it's been freakin' BUSY here the last two days!
    2nd of 4 (my sc-fi name tonight), hopefully it mellows out a bit.
  19. Nov 10, 2017 at 9:44 PM
    Matic
    Tricky Dick
    Easley, SC
    Off tonight.
    Enjoying some live PD and debating on cars and coffee in the morning.
    StainlessSteelRatt and Key-Rei like this.
  20. Nov 10, 2017 at 9:52 PM
    Sammie
    Sammie :D :P ;)
    NC
    ‘17 Tacoma BBP
    In for 4/5 :bananadead:
