GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. Jul 25, 2018 at 9:27 PM
    medic2230
    Murph
    Bama! Roll Tide
    How was I supposed to know you were in here too?
    ETsemaj likes this.
  2. Jul 25, 2018 at 9:29 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Read the title :evil: :D
    And I'm broadening the shows base :rofl:
  3. Jul 25, 2018 at 9:31 PM
    medic2230
    Murph
    Bama! Roll Tide
    Well you better get back to the show dammit. We're losing listeners.
    ETsemaj likes this.
  4. Jul 25, 2018 at 9:34 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I'm about to step outside for a "breathing treatment" :D Let's go to commercial
    medic2230[QUOTED] likes this.
  5. Jul 25, 2018 at 9:36 PM
    StainlessSteelRatt
    StainlessSteelRatt Well-Known Member
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Icon, SPC, OME Dakar, Mobtown, OTT Tune
    Yeah.
    A local shop here recommended against pizza cutters because Colorado roads are so bad. They're GREAT offroad from what I hear, but they wander pretty badly on rutty asphalt like we have here.
    robssol likes this.
  6. Jul 25, 2018 at 9:58 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Ed
  7. Jul 25, 2018 at 10:08 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Not much Phillip, you?
    Pulling a couple of 12p-12a shifts before I go to straight 6a-6p, it's been a pretty easy transition so far! :thumbsup:
  8. Jul 25, 2018 at 10:34 PM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
  9. Jul 25, 2018 at 10:36 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Half day tomorrow and then harpoon BBQ festival
  10. Jul 25, 2018 at 10:39 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    What’s a “pizza cutter”?
  11. Jul 25, 2018 at 10:42 PM
    m603holden
    Marteeen
    New England
    Tall skinny tires. Like 255/85r16
  12. Jul 25, 2018 at 10:44 PM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    That's always a good thing :D
    Evenin Tim
    Sup Max
  13. Jul 25, 2018 at 11:12 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I think I've been going about tires wrong. I always thought to go bigger, the first number went up, not the second... So really I want 265/80/17s if I want to go 33s?
    On another subject, what gets me through the long nights at work is stuff like this lol
  14. Jul 25, 2018 at 11:19 PM
    TownvilleTim
    Tim
    Townville, SC
    265 section width in mm
    80 aspect ratio (%)
    17 wheel dimaeter in inches
    Side wall height is 265mm x 0.80 So the numbers go hand in hand.
    Total = (265/25.4) * 0.80 * 2 + 17 = 33.69"
    Slashaar[QUOTED] likes this.
  15. Jul 25, 2018 at 11:26 PM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
  16. Jul 25, 2018 at 11:36 PM
    m603holden
    Marteeen
    New England
    Or more commonly 285/75r16
  17. Jul 25, 2018 at 11:36 PM
    Slashaar
    Josh
    Kansas City, MO
    I'm just curious whether I should increase aspect ratio or tire width to gain height. I'm running 265/70r17s currently and just put in a 1.5-2" lift in the front and the same in the rear (5100s on second setting with OEM Sport coils, 3rd gen leafs with Icon AAL).
    Edit: Still running OEM UCAs otherwise id get the full 3" from them.
    :threadjacked:
    Sorry, return to your scheduled programs.
    robssol likes this.
  18. Jul 25, 2018 at 11:41 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    If you increase any of the 3 numbers without changing anything else, the tire will be taller. The first number is width, so changing that number will make the tire wider, but also make it taller because the second number is a percentage of the first number. The second number determines sidewall height (the amount of rubber between the rim and the tread), so making it bigger makes the tire taller without being wider. Third number is obviously rim size.
  19. Jul 25, 2018 at 11:43 PM
    m603holden
    Marteeen
    New England
    Next bump up is pizza cutters or 285/70r17 and 285/75r16, I believe.
    Pizza cutters are generally less of an issue. The others, you're cutting .Haha
    Slashaar likes this.
  20. Jul 25, 2018 at 11:44 PM
    Slashaar
    Josh
    Kansas City, MO
    Okay, so I was on track. The internet, place of confusion. 285's and cutting it is!
