GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. Feb 5, 2019 at 12:15 AM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I'll save it for later when I have some extra monies :D
    m603holden likes this.
  2. Feb 5, 2019 at 12:16 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    So you don't have to use their soap? I can use my regular car soap?
  3. Feb 5, 2019 at 12:16 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    They work just as well washing the house siding. North side gets pretty dingy every couple years, so I bath the house.
  4. Feb 5, 2019 at 12:18 AM
    koditten
    Kirk
    Central Michigan
    Honestly, I don't know. If I had a brand new truck, I might care more. I just want the thing clean.
  5. Feb 5, 2019 at 12:18 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    There are two kinds . One uses a hose like miracle grow . The other uses a pressure washer. I have the oressupr washer one fyi.
  6. Feb 5, 2019 at 12:18 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
  7. Feb 5, 2019 at 12:19 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    What I have...
    With this setup I can (and have) wash in full sun and not leave any spots. Adam’s Polish.
    Pibbles99[QUOTED] and m603holden like this.
  8. Feb 5, 2019 at 12:19 AM
    koditten
    Kirk
    Central Michigan
    Yep. The one with the pressure washer is the best.
    Pibbles99 likes this.
  9. Feb 5, 2019 at 12:19 AM
    m603holden
    Marteeen
    New England
  10. Feb 5, 2019 at 12:21 AM
    koditten
    Kirk
    Central Michigan
  11. Feb 5, 2019 at 12:23 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Converted an Old water fire extinguisher to a foamer. Just charge it with soap, water & compressed air. Works pretty good.
    Bigdaddy4760, RobP62, robssol and 3 others like this.
  12. Feb 5, 2019 at 12:23 AM
    m603holden
    Marteeen
    New England
    Well that's cool
    Bigdaddy4760 likes this.
  13. Feb 5, 2019 at 12:25 AM
    FastEddy59
    Eddie
    They were throwing out all the water ones so I grabbed a couple. Glad I did.
    m603holden[QUOTED] likes this.
  14. Feb 5, 2019 at 12:25 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
    I have a pressure washer
    Sup Michael
  15. Feb 5, 2019 at 12:26 AM
    koditten
    Kirk
    Central Michigan
    There you go. What's $20?
    RobP62 and m603holden like this.
  16. Feb 5, 2019 at 12:27 AM
    gixxerphil
    Phillip
    Auburn, Alabama
    2013 DCLB
  17. Feb 5, 2019 at 12:27 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    RobP62 and robssol like this.
  18. Feb 5, 2019 at 12:27 AM
    mjbtaco
    Michael
    Montclair , so cal
    hi
  19. Feb 5, 2019 at 12:28 AM
    m603holden
    Marteeen
    New England
    Yup. Then that's the one to go with. The suds get layered on so thick you can actual hear the foam hitting the pavement as it slowly drops off the truck
    I follow up with this for a sealant instead of each these days
    Chemical Guys WAC_808_16 Hybrid V7 Optical Select High Gloss Spray Sealant and Quick Detailer (16 oz) https://www.amazon.com/dp/B004UPZXQM/ref=cm_sw_r_cp_apa_i_GIuwCbNP8BPZ0
    That's what made the water bead in those photos . And that was just a no soap rinse after wheeling
    FastEddy59 likes this.
  20. Feb 5, 2019 at 12:28 AM
    koditten
    Kirk
    Central Michigan
    If that soap works with a soap gun, then yes.
    Pibbles99[QUOTED] likes this.
