GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. Feb 28, 2019 at 6:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm sure it will be running, but I have to source throttle/choke cables. The originals were on the right side of the single cylinder motor. The twin has those on the rear. Need them about 16" longer.
    I'm okey with changing them. I don't like simplicity, dual paddlle levers. They are expensive as well as not being very decent quality.
    Slashaar and Bigdaddy4760 like this.
  2. Feb 28, 2019 at 6:44 PM
    koditten
    Kirk
    Central Michigan
    Just got done blowing up TW live with pics. I'll do a detailed build thread this coming weekend.
    Slashaar, Pibbles99 and Bigdaddy4760 like this.
  3. Feb 28, 2019 at 6:50 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Ok The drain plug on my truck is on the bottom and the fill port is on the side ( rear) is it the same on my model on the front I haven’t looked yet. I do feel like an idiot
    Slashaar[QUOTED] likes this.
  4. Feb 28, 2019 at 6:51 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Bruins putting a pasting on the lightning
    Slashaar and m603holden like this.
  5. Feb 28, 2019 at 6:52 PM
    koditten
    Kirk
    Central Michigan
    Good!
    Slashaar likes this.
  6. Feb 28, 2019 at 6:54 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    In ten thousand I will need to pug in my third set of plugs. I found out at 42K that it was every 30 so I’m good there.
    Really need to get those fluids changed. Good weather is around the corner or I can call my neighbor and use his lift
    Slashaar and FastEddy59 like this.
  7. Feb 28, 2019 at 7:44 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Any recommendations on high lift jack stands
  8. Feb 28, 2019 at 7:44 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Can you show me a pic of that?
    I have an extra sprayer
  9. Feb 28, 2019 at 7:46 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    @Bigdaddy4760
    What is the gross weight of those Cat 993’s ?
  10. Feb 28, 2019 at 7:47 PM
    koditten
    Kirk
    Central Michigan
    Sorry, not at shop now.
    Just cut a piece of the hose and take it to your nearest home/hardware store and ask for a 1/4 turn shut off valve.
    Slashaar and Pibbles99[QUOTED] like this.
  11. Feb 28, 2019 at 7:48 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    This 938 is around 40,000
  12. Feb 28, 2019 at 7:51 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    I would have to check but it’s a lot
  13. Feb 28, 2019 at 8:00 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    The front is a hex bolt, youll need an allen wrench for it, and possibly another wrench to use as a breaker bar... Mine was stiff.
    Pibbles99[QUOTED] likes this.
  14. Feb 28, 2019 at 9:13 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Well back at it guys, night 1 of 4 well underway. Hope everyone is doing well, need to do a better job of keeping up with this thread when not on shift
  15. Feb 28, 2019 at 9:13 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Hey Danny
    RockHed[QUOTED] likes this.
  16. Feb 28, 2019 at 9:14 PM
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Sup Danny
    RockHed[QUOTED] and Bigdaddy4760 like this.
  17. Feb 28, 2019 at 9:24 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Wazzzzup.
    Everyone doing the @koditten tnite?????
  18. Feb 28, 2019 at 9:25 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    What’s up
  19. Feb 28, 2019 at 9:27 PM
    m603holden
    Marteeen
    New England
    Struggling tonight. Couple of T rotation weld jobs with high tolerance . Some inspection. Can't wait to get home and slam some NyQuil to get back to bed haha. How are you Maner?
    Good morning everyone else as well
    Bigdaddy4760[QUOTED] likes this.
  20. Feb 28, 2019 at 9:31 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Doing good, pulling a @gixxerphil and buying shop tools tonight.
    You sick again
    Slashaar and m603holden[QUOTED] like this.
