GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. May 15, 2017 at 7:12 PM
    aggietaco
    aggietaco Well-Known Member
    Texas
    2021 2500hd custom
    Staying up late tonight getting ready for 3 nights starting tomorrow. Got sunburned as hell today working outside on my one day off. Also found a big bee hive in the water meter box while out mowing.
    Wabs38 and Longshoreman like this.
  2. May 15, 2017 at 7:34 PM
    Longshoreman
    Longshoreman Well-Known Member
    CA.
    2013 Tacoma off road & tow package
    Toytec coilovers Fabtech uca's Dakars and 5100's in the back.
    One day off and you had the energy to do the yard work. You must be in shape...
  3. May 15, 2017 at 7:36 PM
    aggietaco
    Texas
    2021 2500hd custom
    I'm covering shifts since we're short a man, so I have to do what I can on my few days off
    Longshoreman[QUOTED] and Wabs38 like this.
  4. May 15, 2017 at 7:48 PM
    Wabs38
    Wabs38 Well-Known Member
    North Carolina
    2003 tacoma
    idk
  5. May 15, 2017 at 8:27 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Acid etched the silhouette of a tarpon. 9 volt battery, cotton swabs and white vinegar.
    Played around with it on my break. Turned out pretty good for my 1st attempt.
    Hopefully I can keep my beer cool for a bit instead of having to chug them because they warm up so fast.
    14 days until I head for the keys to do some fishing:)
  6. May 15, 2017 at 8:51 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Looks like it left a good etch. :thumbsup: Haven't tried it on the tumbler cups but have done it to glassware before. We used contact paper for making stencils.
  7. May 15, 2017 at 9:05 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Guess, very destructive as adults.:annoyed:
    Think hard.:rolleyes:
    We have a winner:laugh:
    Fucker set up house in the loft of our shed had its babies and abandoned them. My wife wanted a no kill option. Found a rescue 80 miles away. They met us half way. I'm happy, but more important my wife is happy!
    Happy wife.
    Happy life!:woot::yay:
  8. May 15, 2017 at 9:05 PM
    koditten
    Kirk
    Central Michigan
    I need to come up with a better method for the stencils. I'll do some You Tubing later to see what is the easiest.
    I'll look into the contact paper trick.
    Misplaced Nebraskan likes this.
  9. May 15, 2017 at 9:37 PM
    robssol
    Rob
    S. Wisconsin
    Or start with colder beer:thumbsup::cheers::drunk:
  10. May 15, 2017 at 9:38 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I hate fucking trailer wiring. rewired it because none of the lights other than the two side markers would work, now, the left rear marker wont light up, and the brake/running light wont come on, but the blinker works, adn the right rear the running light dosent go out when the blinker comes on.... i don't know WTF is going on, as all the wiring test out just fine on a voltmeter
  11. May 15, 2017 at 9:49 PM
    koditten
    Kirk
    Central Michigan
    What kind of meter?
    I found that using a digital multi meter is not the best. Use the old school analog units to save your sanity.
    The "ghost" voltage will drive you nuts. A good, old needle and dial is the best way.
    Watt maker likes this.
  12. May 15, 2017 at 9:52 PM
    koditten
    Kirk
    Central Michigan
    Well, when the ambient temp is 90*, it don't stay cold very long, no matter how cold it was when it first gets opened.
    I kinda want to enjoy a beer while sitting on the boat.
    I do like to slam down my beers on a regular occasion, but in this case, I want to take it slow.
    robssol[QUOTED] likes this.
  13. May 15, 2017 at 10:44 PM
    robssol
    Rob
    S. Wisconsin
    If you're using a 7-way, check for correct wiring in the plug. Clean out the bulb sockets. Check the ground side of the sockets back to ground in the plug. A little lithium grease in the connections wouldn't hurt.
  14. May 15, 2017 at 10:47 PM
    robssol
    Rob
    S. Wisconsin
    Huh?
  15. May 15, 2017 at 10:48 PM
    Gaunt596
    Matthew
    Central Maryland
    7 Pin, theres a ground in the plug as well as a ground bolt on the trailer, and all the lights ground directly to the trailer, theres only one wire for power for each light. The lights im having issues with are these exact ones https://www.etrailer.com/Trailer-Lights/Optronics/ST2RB.html The lights ground through the two mounting bolts, and theres one wire for the side marker, and one wire for the brake/turn signal/running light. I thought it was the ground as well, but the bolts make contact with bare trailer metal so they should have a good ground.
  16. May 15, 2017 at 10:52 PM
    Gaunt596
    Matthew
    Central Maryland
    yeah, it is a digital one, although i do happen to have an old analog meter as well, ill give that a shot
    plug is wired correctly, the trailer functioned as it should before the lights stopped working, the thing isn't even two years old, im the first owner
  17. May 15, 2017 at 10:58 PM
    robssol
    Rob
    S. Wisconsin
    Apply LITHIUM GREASE to your connections. Worked many times for me in the past. Both of my trailers are 10+ years old and the lights work perfectly.
  18. May 15, 2017 at 11:01 PM
    Gaunt596
    Matthew
    Central Maryland
    Ill give it a shot, although the bulbs in the lights dont actually have a socket, theres a small plastic tab to hold the bulb and it kinda rubs up against two copper strips and a steel piece for power and ground.
    robssol likes this.
  19. May 15, 2017 at 11:04 PM
    robssol
    Rob
    S. Wisconsin
    7-way as well. Even more important than the sockets.:thumbsup:
  20. May 15, 2017 at 11:08 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    2 of 5.
    Yaaaawn....
