GraveYard Shift BS
Discussion in 'Off-Topic Discussion' started by Mondwa, Feb 2, 2010.
  1. Aug 19, 2017 at 3:07 AM
    aggietaco
    aggietaco Well-Known Member
    Texas
    2021 2500hd custom
    There's one of the bigger relay that's labeled TOW TAIL if that's what you're referencing?
  2. Aug 19, 2017 at 3:14 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Owners manual diagram? or is there one under the lid, or is that what you're referencing?
  3. Aug 19, 2017 at 3:19 AM
    aggietaco
    Texas
    2021 2500hd custom
    It's labeled on the underside of the lid. Checked all the fuses related to the towing/trailer and they're all good. I removed the ground on the trailer and the running lights still work, so not sure what's going on there.
  4. Aug 19, 2017 at 3:39 AM
    Misplaced Nebraskan
    Zach
    Austin
    Yeah, that is odd. Grounding somewhere for sure.
  5. Aug 19, 2017 at 3:41 AM
    aggietaco
    Texas
    2021 2500hd custom
    It's gotta be the truck like @koditten said though since it worked just fine with the tacoma
  6. Aug 19, 2017 at 3:42 AM
    aggietaco
    Texas
    2021 2500hd custom
    And got the new ground wired up on the trailer and still no luck.
    Misplaced Nebraskan likes this.
  7. Aug 19, 2017 at 3:42 AM
    Misplaced Nebraskan
    Zach
    Austin
    Very valid point. Sucks to have to take it back in but at least it'll be free (should) or maybe just eyeball all the wiring just to double check first before dealer hassle.
    aggietaco[QUOTED] likes this.
  8. Aug 19, 2017 at 3:54 AM
    aggietaco
    Texas
    2021 2500hd custom
    I did notice that there's a fuse and relay labeled LED DRL on the fuse box, but the fuse and relay are missing. I doubt they're related to trailer lights though
  9. Aug 19, 2017 at 5:10 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
  10. Aug 19, 2017 at 5:21 AM
    Misplaced Nebraskan
    Zach
    Austin
    :luvya::cheers:
    robssol[QUOTED] likes this.
  11. Aug 19, 2017 at 6:07 AM
    Sammie
    Sammie :D :P ;)
    NC
    ‘17 Tacoma BBP
    It's bed time!
  12. Aug 19, 2017 at 6:58 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    good luck, im having a similar issue with my Tacoma and a Chevy Suburban. im actually about to rewire the entire trailer and see if that fixes it. one thing you might check, is to see that the pinout on the trailer plug is. theres two ways to wire a seven pin, RV style and Commercial, IIRC the Tacoma's are set up for RV style from the factory, but the tundra may be on commercial and some wiring is switched.
    aggietaco[QUOTED] and Fitzwilly like this.
  13. Aug 19, 2017 at 7:05 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That's for canada trucks. We don't require them yet in the states.
  14. Aug 19, 2017 at 7:29 AM
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    This is very good to know, thanks for that tidbit.
  15. Aug 19, 2017 at 9:57 AM
    koditten
    Kirk
    Central Michigan
    Testing the plug with a digital multi meter is a pain. The "ghost" voltage will confuse you every time. I keep an analog meter for just such a reason. seeing the needle sweep in time with the signal is much easier than watching numbers climb and recede.
  16. Aug 19, 2017 at 10:08 AM
    Gaunt596
    Matthew
    Central Maryland
    I have a digital, but it also has a small graph under the number readout showing the voltage directly without any digital processing. its a nifty feature for stuff like that.
  17. Aug 19, 2017 at 5:50 PM
    Misplaced Nebraskan
    Zach
    Austin
    4 of 4. Got 6 1/2 lb venison burgers about to go on the george foreman for the 3 of us here... NFL on as background noise. :hungry::bananadance: Will post pic later :thumbsup:
    MQQSE and aggietaco like this.
  18. Aug 19, 2017 at 5:53 PM
    aggietaco
    Texas
    2021 2500hd custom
    Breaking in the new wok :D
    MQQSE and Misplaced Nebraskan like this.
  19. Aug 19, 2017 at 5:54 PM
    Misplaced Nebraskan
    Zach
    Austin
    Which wok? I'm loosely looking for one...
  20. Aug 19, 2017 at 6:17 PM
    Fitzwilly
    Bill
    South Central Mass
    Got my LED tail lights via UPS just as we were getting home from our first Ice Cream outing of the summer... I'll likely install them tomorrow.
