Gravity Brake Bleeding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff2020, Mar 26, 2025.
  1. Mar 26, 2025 at 12:01 PM
    Jeff2020
    Jeff2020 [OP] Active Member
    What you guys think of just opening all 4 bleeders attached to 3/16-inch or 1/4-inch bleeder hose dropped in 4 buckets. Checking & refilling the master cylinder.
  2. Mar 26, 2025 at 12:01 PM
    MGMDesertTaco
    Doesn't work. Get a mighty vac hand help pump if you don't have a helper.
    BillF1564 likes this.
  3. Mar 26, 2025 at 12:07 PM
    Jeff2020
    Why not?
  4. Mar 26, 2025 at 12:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sometimes it works, sometimes it doesn't. Give it a try. If the pedal is still soft then you'll have to get a helper to foot bleed it with you
  5. Mar 26, 2025 at 12:11 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    That's an interesting question.
    If it would work, you'd definitely want to open the bleeders sequentially, not simultaneously.
  6. Mar 26, 2025 at 12:16 PM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    I've been successful doing gravity brake bleeds on older Toyotas ( '05 Tundra, '99 4runner, '12 Rav4). Don't know why it wouldn't work on a Tacoma.
  7. Mar 26, 2025 at 12:16 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Start with the bleeder furthest from the master cylinder,so passenger rear. Do them one at a time and make sure you keep the master full. The closer you get to the master the quicker it drains.
    BillF1564 and RockBunny like this.
  8. Mar 26, 2025 at 12:22 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I'd just try to find a helper and do it the normal way. It may end up working but it's slow.
    Why do you need to bleed? Just replacing fluid or do you have an air problem?
  9. Mar 26, 2025 at 12:26 PM
    Jeff2020
    I have done some of the recommended maintenance: Oil, transmission drip and fill, differential, battery. Haven't done the coolant & break fluid yet. Just came across a video about gravity bleeding. IMO, the guy seems pretty knowledgeable and he is talking the easiest way to bleed the brakes. It's amazing if it works. You don't need anything but time.
    https://www.youtube.com/watch?v=PBpW-OHYAQk&t=645s
  10. Mar 26, 2025 at 12:44 PM
    Jeff2020
    Got 75K on it and didn't know that brake fluid should be replaced every 2 years. It's not mentioned in the maintenance guide. Also, don't have a reliable helper.
  11. Mar 26, 2025 at 12:52 PM
    MGMDesertTaco
  12. Mar 26, 2025 at 12:52 PM
    jmneill
    SE
    Every two years is huge overkill.
    It would absolutely still test fine under all but the most unusual circumstances.
  13. Mar 26, 2025 at 12:56 PM
    Jeff2020
    I got a tester from Amazon and it showed <1%.
  14. Mar 26, 2025 at 1:01 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Yes it will work just fine. And yes you can crack all the bleeders at the same time.
  15. Mar 26, 2025 at 1:06 PM
    jmneill
    SE
    So still good @ 75K..
  16. Mar 26, 2025 at 1:20 PM
    Jeff2020
    Thank you guys, I am going to get 2 Toyota Dot 3 and copy/follow the guy in the video. The only thing I am going to add is attaching 4 bleeder hoses to direct the drops into buckets. The way I understood, no need for a helper, no pumping the breaks, & no need for any fancy vacuum pump/pressure pump that may not work. Just like watching the paint dry.
  17. Mar 26, 2025 at 1:37 PM
    MGMDesertTaco
  18. Mar 26, 2025 at 1:39 PM
    Jeff2020
    Have tried it & didn't work? Or, you are just guessing.
  19. Mar 26, 2025 at 2:43 PM
    RockBunny
    Northern NH
    ^^^ Please read again. I am saying there should be no reason that it would not work on a Tacoma. When I have the need, I will be doing a gravity brake bleed on my truck.
  20. Mar 26, 2025 at 2:45 PM
    Jeff2020
    I misunderstood, thanks for clarification.
