greasable shackle bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbrandt, Dec 22, 2011.
  1. Dec 22, 2011 at 2:17 PM
    jbrandt
    jbrandt [OP] Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Hey all,
    So I have a set of Toytech 1" lift shackles on my '04 TRD 4x4. I just put them on last weekend, along with all new urethane bushings on all 4 corners (and 5100's).
    I was thinking of replacing the bolts with greasable ones (all 3 bolts on each leaf).
    1st, what are your thoughts on them (are they weaker, etc...?). Is it worth it, etc...?
    2nd, can you recommend a place to get them? All I can find are shackles WITH the geasable bolts, not just the bolts, or bolts that aren't specific to the Taco.
    Thanks!
  2. Dec 22, 2011 at 2:54 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have the OME greasable shakles and I havent had any issues with them, but I also never had any issues with stock non-greasable bolts either.
  3. Dec 22, 2011 at 2:58 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have the OME greasable shackles and have had no issues. I also purchased the greaseable spring eye bolt from Wheelers Off Road, although not installed yet.
  4. Dec 22, 2011 at 5:17 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Got mine from NWOR. Love 'em. Then seem to eat grease a little faster than the driveshafts but it def makes life easier.
