Grease Fittings on 5 Lug
Discussion in '5 Lug' started by justinh384, Aug 7, 2014.
  1. Aug 7, 2014 at 4:42 PM
    justinh384
    justinh384 [OP] Active Member
    Justin
    Wrightsville, GA
    2017 White Toyota Tacoma SR
    I've been doing my own maintenance on my 5 lug for well over a year now and have never came across a grease fitting anywhere on the truck. I was just wondering if there are any and the type of grease that I'd need to use.
  2. Aug 7, 2014 at 5:49 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    There aren't any grease fittings on the 5 lug unless you replace factory parts with aftermarket, such as u-joints or outer tie rod ends.
