Grease Fittings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by topcathr, Jul 16, 2010.
  1. Jul 16, 2010 at 7:58 AM
    topcathr
    topcathr [OP] Well-Known Member
    2015 limited
    Does anyone have zerk (grease fittings) on their front driveshaft.
    I am talking about the one that goes to the front differential.?
  2. Jul 16, 2010 at 8:01 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I believe I do. I know their a pain in the ass to get to!!!
  3. Jul 16, 2010 at 8:03 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
  4. Jul 16, 2010 at 8:05 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Two...one for each u-joint. I had to turn the shaft by hand and the one at the t-case end was a bitch to reach w/out removing the rock shield under it.
  5. Jan 19, 2012 at 11:59 PM
    daughetc
    daughetc Member
    2010 4x4 TRD
    got a 2010 4x4 double cab trd - all grease fittings on the drive shafts front to back appear to be sealed - as in "no greasing to be done" - ever.
    Does this sound right?? Previously had an 05 and 08 and both could be greased but not this one, apparently - can I get an expert to comment on this ?
    thx
  6. Jan 20, 2012 at 12:26 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    how can you tell that fittings are sealed? I mean if you see the fittings then hook up the grease gun and squirt some in
  7. Jan 20, 2012 at 12:47 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    doesnt sound right. my 2010 has grease zerks
  8. Jan 20, 2012 at 2:34 AM
    daughetc
    daughetc Member
    2010 4x4 TRD
    i can see the zerks on the 2010 as they were on my 05 and 08 but they are sealed over with some hard paint or plastic material - it is obvious that they will not take grease without some modification/material removal or other. service manager at local dealer says that this is normal and they are not to be greased - just fishing for another witness - after 53 yrs i've learned the the truth does not always come thru the first time you ask. actually i'll likely not be satisfied until and can find something documented from toyota.
    thx again
  9. Jan 20, 2012 at 3:50 AM
    Yoytoda
    Roland
    completely stock
    sealed u joints dont have zerks...
    post a picture. worst case scenario,all you would have to do is unscrew the "sealed zerk" and put normal ones in...
    when my truck was new they looked all black with paint but as soon as you put a grease gun to it and pump once the little ball allowed grease in no problem. a lil paint wont stop the hundreds of PSI a grease gun can exert
  10. Jan 20, 2012 at 5:04 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
  11. Jan 20, 2012 at 5:20 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    If your grease zerks still have factory paint on them, it means whoever changed your oil did not do their job correctly. The drive shafts (both of them) should have been lubricated, but weren't. Just wipe any dirt off of the zerks and put your grease gun to them.
    In the future, point out to whoever changes your oil that greasing is part of the job and that trucks have grease zerks. Most cars today do not have any zerks.
  12. Jan 20, 2012 at 5:26 AM
    fubar718
    fubar718 Well-Known Member
    Jose
    NJ
    2010 double cab, TRD offroad
    they are just painted over, if you put a grease gun to them it will fill up the bushing...
  13. Jan 20, 2012 at 6:46 AM
    daughetc
    daughetc Member
    2010 4x4 TRD
    thx to all!
    i change my own oil - zerks are coated over unlike the other 2 tacs i had - just the facts ok - u may be right just push the gease in - BUT - be careful! - yes I have done research in the waining hrs....... If these babies are truelly sealed from factory - i may push non-compatable grease in there - will suspend further relpies until i have manf response - would not want to sound stupid for my hi-north buddy.
    thx
  14. Jan 20, 2012 at 6:56 AM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    Just greased my 2012 V6 4x4 and there were 5 zerks in total. The front shaft had one on each end the front one was painted over and the rear I needed to remove the shield to get to it. Easy 2 bolts to remove. They all took a few pumps so it was needed.
  15. Jan 20, 2012 at 7:57 AM
    Yoytoda
    Roland
    completely stock
    just use LB grease youll be fine. Toyota wont likely have an answer for you because 90% of the techs are idiots...
    U joints are mechanical, its not like brake fliud where dot 3 vs 4 can have adverse effects on seals or something. NGLI 1 or 2 will provide good protection on ujoints.
    if they have zerks they are greasable. If they were sealed from the factory there would be no zerks...
  16. Jan 20, 2012 at 10:07 PM
    daughetc
    daughetc Member
    2010 4x4 TRD
    thx yoytoda (and all).
  17. Jan 21, 2012 at 3:43 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    Daughetc - if you just bought a used 2010, it's not uncommon for a dealer to do an undercoating to remove the look of surface rust. I recently went to look at a 2009 with a coworker at the dealer and everything underneath was coated black - coils, shocks, everything.
  18. Jan 24, 2012 at 2:14 AM
    daughetc
    daughetc Member
    2010 4x4 TRD
    thx again - yes it was just paint undercoat - 5 zerks in all- believe or not i was able to get to the one with the sheild by using a small gun with small delivery spout - used NGLI II.
    and one other note - it was not a minute too soon- after 30000mi - though I normally only drive in wussy conditions some joints spurted out a little moisture and air - not good - but all seems ok and they got the lube NOW.
  19. Jan 24, 2012 at 1:11 PM
    Yoytoda
    Roland
    completely stock
    I noticed when I got my truck the joints took a good 5 pumps. Pretty dry in my opinion. At 30k they only took 1 pump and 50k they only took 1 pump.
  20. Feb 25, 2012 at 5:42 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    I just greased mine today, all but the rear one on the front drive shaft anyway. Just the other day I had the "free" 5000 mile service at the dealers, they didn't touch the zerks because they were still painted over. They all took at least 5 pumps...pretty dry.
    Anyone try turning the rear zerk on the front drive shaft to make it more accessible?
