Grease for OEM upper ball joints?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Mar 19, 2016.
  1. Mar 19, 2016 at 12:25 PM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    took my spindles to an independent shop to have my old UBJ's pressed out and had new OEM ones pressed in. When I got the spindles and old parts back in a box I noticed the supplied packages of grease were still partially full, or were. They were smeared all over the inside of the box and on the old parts. This makes me think they didn't put much if any grease in the boot.
    My solution is to take a syringe and fill it with the grease and pump it into the boot. My question is what type of grease should I use? They might have put a little of the supplied stuff in so comparability is a concern.
    I'd go back but it was a "$60,no receipt" deal so they might even deny they did the work. Who knows, but I'd rather handle it myself.
    Thanks.
    Biscuits likes this.
  2. Mar 19, 2016 at 2:48 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    They make a needle tbat goes onto the end of a grease gun just for this occurrence. Theyre super cheap.
  3. Mar 19, 2016 at 2:49 PM
    Trapperr
    Reno, NV
    I had no idea! Thanks! Any suggestions on the grease?
  4. Mar 19, 2016 at 2:58 PM
    bry838
    oregon
    I dunno, i cant really imagine it matters too much??
  5. Mar 20, 2016 at 8:57 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    As odd as it sounds, the little packet of lube supplied with an OEM upper joint kit is intended to lube the upper "lip" of the boot where it contacts and rotates against the upper control arm. This only requires a small "smear" and one packet would likely do 10 boots. The joint itself is pre-lubed with all the lube it will ever need.
  6. Mar 20, 2016 at 8:59 AM
    Trapperr
    Reno, NV
    Not doubting you at all since you know more than I on these topics but the instructions said to fill the boot with one of the supplies bags of grease.
  7. Mar 20, 2016 at 9:03 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Fine, then go for it. Of the dozen or so I have done the instructions specifically said to apply lube to the upper lip of the boot. I haven't bought any for a few years so they might have changed it.
