Grease Gun
Discussion in '1st Gen. Tacomas (1995-2004)' started by Janko630, Jan 3, 2022.
  1. Aug 25, 2022 at 12:39 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Thanks. It's Lucas Red and Tacky.. so perhaps the tacky attribute helped in my frustration. It also had just come from a well air-conditioned auto parts store so was wondering if that contributed to the continual failures to retain prime as well. Both guns I have are cheapos so perhaps I'll at least try a name-brand or quality gun before handing over the cash for an electric. Mainly what should've been a 5 minute job turned into a charlie foxtrot situation.
  2. Aug 25, 2022 at 1:06 PM
    alexh
    alexh Well-Known Member
    1998 TRD
    That Lincoln works fine for me, pops off the zerk once in a while so perhaps that adapter is worth it - otherwise I hold the hose end with one hand and place the gun on the ground or against my body (cant quite recall) and pump with one hand . I asked about using Moly grease on all U-joints when I first bought my 1st gen truck new and was told that its fine - I asked because I believe the cardon specs moly whereas the others are gen purpose or something like that and of course changing grease types is not fun.
    wesb1023 likes this.
  3. Aug 25, 2022 at 3:46 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Very well could have been one problem. My continuous shot Lincoln pneumatic, that finally broke on me, was the easiest gun I’ve ever had to prime. When the rod was locked to the piston to pull against the spring, you could also push the rod in this same position. This meant that to change the tube, you locked the rod to the piston, unscrewed the barrel, pull and let go of the rod to chuck out the old container, lock rod/piston back collapsing spring, install new tube, then just unlock rod from barrel to allow spring pressure against grease……in this position, with this grease gun you also had the option to push on the end of the rod and it would apply spring pressure plus whatever pressure you’ve applied to the rod. When it finally primed, twist and unlock from the piston and push it up into the tube for storage.
    Whatever you buy, it will pay to do your homework first, don’t just get the first one you see.
    As with all of my cordless tools at work I went with snap-on, if I had done my homework first and not just bought what was in front of me at the time, I’d probably own everything Milwaukee right now.
    Whichever gun you choose to purchase, read the directions, lots of times you will learn something and find out that there’s probably at least 3 different ways to refill that grease gun.
    Gen3TacomaOBX[QUOTED] likes this.
  4. Aug 25, 2022 at 7:18 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Whatever gun, I've got at least 4, all different. The important thing is the locknlube, makes life way easy.
  5. Aug 26, 2022 at 8:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I agree. I've done some research on grease guns, and the one I will buy before my next grease job is the air-powered one made by Lincoln. It's sold at Home Depot for $62. When it's in stock, that is...
  6. Aug 26, 2022 at 10:17 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Another one for the locknlube.....gun aint important....
    worth every 3000 freakin pennies.....
    It is nice to have an extra gun with a super long hose permanently attached....
  7. Aug 26, 2022 at 10:57 AM
    theschnouz
    theschnouz Well-Known Member
    I just picked up a LockNLube pistol grip grease gun, much easier to use under the truck greasing the drive shaft.
    nagorb[QUOTED] likes this.
