grease guns and zerk fittings.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Stallion, Aug 24, 2019.
  1. Aug 24, 2019 at 12:05 PM
    Black Stallion
    Black Stallion [OP] over-worked & under-paid
    Paul
    Western Washington
    2015 MGM TRD SPORT Access Cab 4x4
    No mechanical mods. Minor convience and useability tweaks.
    I was servicing my "new-to-me", 2015 4wd Tacoma and ran into a slight problem. When lubing the driveshaft, I had no problem with the three fittings on the rear driveshaft, but was stumped on the two fittings on front drive shaft. The nozzle on my grease gun is too large to fit into the cavities where the fittings are located. What are you guys and gals using that will fit in there and do a good job?
  2. Aug 24, 2019 at 12:08 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    A smaller gun that holds the 3 oz. tubes might help.
  3. Aug 24, 2019 at 12:10 PM
    2013djb67
    2013djb67 They can coexist.
    David
    2013 Charcoal Tacoma TRD
    Six inch lift brush bar roof rack leds all around rims and tires
    Use a needle injector it is about 2 inches long fits up in there nicely.
    4x4cajun and spitdog like this.
  4. Aug 24, 2019 at 12:36 PM
    Black Stallion
    Paul
    Western Washington
    Thanks! I'll give those suggestions a try!
  5. Aug 24, 2019 at 7:00 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    You have to rotate the shaft slowly till you find where the nozzle fits on zerk, on mine the u-joint at the t-case the zerk has to be pointed at roughly two o-clock for the nozzle to fit in the drv shft and hit the zerk, the one at the front diff I don't remember any tricks so it must just fit.
    ABNFDC, QChawks and DrFunker like this.
  6. Aug 24, 2019 at 8:15 PM
    brac2015
    brac2015 Well-Known Member
    Dan
    Victoria BC
    Barcelona Red 2015
    That's what I have and works on both shafts.
  7. Aug 24, 2019 at 8:48 PM
    TacoTuesday1
    FL
    would a flexible hose attachment help?
    some of them come with it
  8. Aug 24, 2019 at 9:39 PM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    needle is easiest.
  9. Aug 25, 2019 at 4:37 AM
    Strxn
    Strxn Active Member
    PA
    '10 BSP DCSB 4x4
  10. Aug 25, 2019 at 4:39 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Flexible hose allows me to access that tricky one on the front shaft. As someone mentioned, I rotate it to around the 2 o'clock position.
    Norton, Plain Jane Taco and 4x4cajun like this.
  11. Aug 25, 2019 at 4:45 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I don't even have zerks on my front..
  12. Aug 25, 2019 at 5:54 AM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Same here. A flexible hose works on the front zerk.
  13. Aug 25, 2019 at 6:35 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Remember the two fronts are 90 degree fittings, at least on mine.
    Also, get a pneumatic grease gun if you have air. Well worth the expense
  14. Aug 25, 2019 at 12:38 PM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    I have this exact gun and was able to do the front shaft one as well. My recall u-joints on lower driveshaft don't even have zerks... so I have this huge grease gun and grease tube for one zerk lol.
    Sig45[QUOTED] likes this.
  15. Sep 24, 2019 at 1:48 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    Did it today myself and it works well. Made it easy to do. It’s the only one that I had to use it for though. I was able to use the LockNLube fitting to get the other 4 zerks with no issues. One suggestion is to make sure you wrap the grease gun fitting with something like Plummer’s tape or something for a leakproof fit.
  16. Feb 11, 2020 at 12:44 PM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    I know this is an old post, and this may be a dumb question....but how do you use that needle injector? Do you push it into the zerk?
    llamasmurf likes this.
  17. Feb 11, 2020 at 1:42 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I could'nt figure out how to use the needle injector, it just made a mess. Ended up for me that the cheap grease gun fittings I can get from 'Canadian Tire' actually fit inside and allow me to grease the 90 degree fittings. They are just the right size.
    Tah-koh-mah[QUOTED] likes this.
  18. Feb 11, 2020 at 1:59 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    With the needle point attachment you need to be able to push that little ball in the zerk in before you pump the grease.
    The needle zert point holds that ball in so the grease can flow into the zert. If your at an angle and that ball doesn’t get push in, your going to have a mess.
    https://www.youtube.com/watch?v=JmJNjg-zEKA
    Tah-koh-mah likes this.
  19. Feb 11, 2020 at 2:20 PM
    Tah-koh-mah
    How much grease are you pumping into them? Are these "flush" type u-joints where you keep squeezing until new grease flows out? I'm not sure if these are the sealed type that shouldn't be flushed or are they flushable? Sounds like I'm talking about toilets lol.
    llamasmurf[QUOTED] likes this.
  20. Feb 11, 2020 at 2:45 PM
    llamasmurf
    Wes
    Northern Ontario
    I didnt know what I was doing when I 1st did mine, so I broke the seals apparently. Now have to flush them until clean grease comes out.
    I was told you just put 'a bit', but that measurement amount is very vague to me. :notsure:
