grease/lube for steering stops on lower control arm?
Discussion in 'Suspension' started by super_white, May 11, 2022.
  1. May 11, 2022 at 2:29 AM
    super_white
    super_white [OP] Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    When leaving work yesterday it felt like my truck was in 4WD (binding/noise). I confirmed it was in 2WD and none of the wheel nuts were tampered with. I drove slowly to make sure everything was good, the ride home was uneventful.
    This got me thinking. What does everyone use to lube the steering stops? I know those could produce the noise I heard but I didn't think I had the wheel fully turned.
  2. May 11, 2022 at 4:13 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I dab a thin layer of grease on mine from time to time --- but that would only be at full lock so I'd try to confirm that is when you get the binding/noise.
  3. May 20, 2022 at 2:51 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Pretty much anything will work and everything will wear/degrade. I have been using green HD Lucas but Id imagine red and tacky would probably work as well.
