Grease Nipples ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vapovick, Aug 26, 2010.
  1. Aug 26, 2010 at 8:06 AM
    vapovick
    vapovick [OP] Active Member
    1999 Toyota Tacoma 4x4
    Ok got your attention haha, I was lubing up the truck, and I only see 3 nipples along the drive shaft. Is that it? are there any on the hubs etc that I am missing?
    Thanks again.
  2. Aug 26, 2010 at 8:08 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if you ever see more than 2 nipples.....stop and run
  3. Aug 26, 2010 at 8:16 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I have 9 zerks
  4. Aug 26, 2010 at 8:17 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    And if they are on the shaft....well then idk what to tell ya. lol
    But anyway, when i greased mine i think i found 4 or 6 if i remember correctly. There should be 2 on the front shaft; one on each end, 2 on the intermediate shaft and 2 on the final shaft.
  5. Aug 26, 2010 at 11:28 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Shit I just did this too, I think there's 7 on mine & no service for the double-cardan, yep pretty sure its 7 for mine, single cabs (1st gens) probably have 1 piece driveshaft
  6. Aug 26, 2010 at 11:31 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If we've got 9 which 2 am I missing? Guess I'll have to check again ....
  7. Aug 26, 2010 at 12:47 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I want to say there's only 7 (for access and double cab), 1 for each u-joint, 1 on the rear shaft itself (slip yoke), and 1 in the middle piece.
  8. Aug 26, 2010 at 12:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The first gens have a double cardan joint that can be greased...You might want to double check yours.
  9. Aug 26, 2010 at 3:57 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Bingo :D there's 2 that are hiding...
  10. Aug 26, 2010 at 4:00 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    There's also 2 more on the leaf spring shackles...
  11. Aug 26, 2010 at 4:07 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    And you don't want to risk messing up that Double Cardan Joint cause I heard it's Expensive :eek:
  12. Aug 26, 2010 at 4:18 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Should be three on the Double cardan better check again 2 are at the ujoint and the one iskinda in the center of both wipe away the grease youll find it
  13. Aug 26, 2010 at 7:23 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    correction 2 zerks on each leaf spring shackle...I just greased mine :rolleyes:
  14. Aug 26, 2010 at 7:29 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    and yes I have a total of 9 zerks along the driveshaft...I just went to grease mine and all the zerks were hidden on the double cardan haha...
  15. Aug 26, 2010 at 8:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Shit ok I've got 8 & I could only find 2 on the dbl cardan, I count 3 for the rear (1-Ujoint on diff,1-Ujoint from tailshaft,1-sliding yoke) 2 for the dbl cardan for a total of 5 for the rear driveline & 3 for the front: 1- Ujoint off transfer to front drvshaft, 1-frnt sliding yoke & 1- for frnt Ujoint bolting up to frnt diff. For a total of 8
  16. Aug 26, 2010 at 8:23 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Can I just buy a standard grease gun with the fitting it comes with in order to grease all the zerks? Or do I need a special fitting?
  17. Aug 26, 2010 at 8:25 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I use a standard tip no problems unless I get sloppy like I did in one pic:eek:
  18. Aug 26, 2010 at 8:33 PM
    96er
    96er Sport Rally'er
    MA
    Thanks man, I guess I pump until it oozes out? Even though that didn't sound good, that is SOP, correct?
  19. Aug 26, 2010 at 8:51 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    He wants to pump his gun into the nipples until it oozes :D
    j/k
  20. Aug 26, 2010 at 9:19 PM
    vapovick
    oh man, look what I have started. I am gonna get back under there on Monday and get the rest done... I guess I have to really clean it up. They seem to be good at hiding.
    ./v
