grease/oil/soda on seats- help?
Discussion in 'Detailing' started by NewTacomaGirl, Feb 8, 2012.
  1. Feb 8, 2012 at 2:12 PM
    NewTacomaGirl
    NewTacomaGirl [OP] Resident crazy cat lady
    My stupid friend was borrowing my truck and -stupidly- didnt put anything on my seats and now I have what I presume to be grease, oil, coffee and/or soda on the seats. Sadly I haven't been able to find seat covers that fit my seats at Walmart or any other stores (havent checked auto zone or such because I cant afford them at the moment and I know I cant afford the custom ones that I want that are $100+ on a website.
    They are darker spots on it and I have used Clorox wipes to clean out my truck and it seemed to clean the windows, center console (was HORRIBLY filthy), cup holders (had cigarette ashes CAKED on), and everything else I found wrong with my truck. I also found burned holes in the carpet from him smoking in my truck (I never let anyone smoke in my truck unless its a e-cig) and there was soda and im guessing coffee spilled all over the doors, cup holder divider I need to replace because my glowsticks exploded and melted the plastic on it but im not to worried about that.
    If anyone knows me they know how pissy I get when my vehicle is messy and not cleaned. I usually clean it out once a week or until it starts getting bad. I need to vacumme it out but that can wait, but does anyone know any product that will REALLY clean out the drivers seat and get rid of what I presume to be grease and oil spots?
    I cant afford detailing or taking it somewhere to get cleaned, and I like to clean it out myself. Does anyone know anything that will REALLY clean the seats and also keep my dashboard looking nice/new? I barely go to car part stores because of work and life, and if i can go in, grab it and know what I need would help out alot.
    No im never letting him borrow my truck EVER again. Not even if his POS jeep is still broken. I HATE people who have no respect for my vehicle or me.
    I cleaned out the truck already as best as I could but here are a few pics of the seat and such.
    Passenger seat:
    Drivers seat:
    right side closest to door:
  2. Feb 8, 2012 at 2:29 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Do you have access to a home carpet cleaner(steam cleaner)? The stains do not look like oil. I would think that a carpet cleaner would be able to remove the stains. I am not certain I would use the Clorox wipes for cleaning your seats, carpet or vinyl. The chlorine may discolor the areas.
  3. Feb 8, 2012 at 2:31 PM
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    Looks more like a drink stain. Ask around for a rug spot scrubber with a hand attachment you could use or borrow from someone and use a solution of something with oxygen in it like resolve oxygen upholstery cleaner (works great for me) or I even use oxyclean/water solution in it.
    This is what I like to use:
  4. Feb 8, 2012 at 2:32 PM
    NewTacomaGirl
    What would work better? and no i dont have access to one sadly. :<
  5. Feb 8, 2012 at 2:42 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That's complete bullshit.. Have him pay for a professtional cleaning.
  6. Feb 8, 2012 at 2:44 PM
    Tacoma Mike
    Southern Maine
    These seats are like a sponge.
    The recon guys use some pretty nasty stuff to clean them. If you use a brush ,use it lightly. If you disturb the mat angle then it will not look right forever.
    Myself i use seat blankets. They look pretty good and I don't have to worry about side air bags or wrestling to put them on. A lot cheaper than seat covers. They stay in place pretty well also..
  7. Feb 8, 2012 at 2:51 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I used stuff like this to clean some serious grease stains out of my tan seats.
  8. Feb 8, 2012 at 3:04 PM
    wolftree
    Rick
    Ohio
    For the vinyl areas, I would use a solution of water and Simply Green or 409 or Mr. Clean and a cloth or sponge. Others may know of better products as well.
    The seats and carpet, I use fabric/carpet cleaner.
    Can you borrow a shop vacum? With the shop vacum, you can really soak the stained seats and pull the water back out of the seats. (Vacum at the carwash???)
    I use my truck as truck, so I am not always the cleanest myself when I get in it. I use ordinary bath towels on the seat and seat backs during those times. At least I use solid color towels, no flowers.
  9. Feb 8, 2012 at 3:12 PM
    joe54tacoma
    joe54tacoma Joe in Indiana
    Joe
    New Albany Indiana
    2012 DOUBLE CAB TRD Sport
    Your truck looks just like mine. Maybe I need to get some seat covers before mine looks like that. Kids are always working on vehicles and riding in my truck.
  10. Feb 8, 2012 at 3:23 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    no offense, but what kind of white trash people do you let use your truck??? lolz
    that really blows and i would be super pissed and would be looking for answers.
    highly disrespectful and completely unacceptable for you to help someone out and they do you like that.
  11. Feb 8, 2012 at 5:06 PM
    NewTacomaGirl
    hahahahhahaahahahaha ya right! He can barely pay his bills! Imma bitch him out until he does. I told him he owes me a detailing and he didnt reply. Supposed to call me sometime tonight and imma tell him or imma call the cops. I love having dirt on him >3
  12. Feb 8, 2012 at 5:08 PM
    NewTacomaGirl
    No, since he works at a truck dealership/shop for big trucks and such i refuse to let him use my truck again and i dont wanna drive a hour to there. He has no respect and leaves TONS of trash, cig ashes, dirt and shit in my car and whines when i bitch him out for messing it up but he doesnt understand why its ok if i mess up my car but he isnt allowed. -.-
  13. Feb 8, 2012 at 5:10 PM
    NewTacomaGirl
    Naw, just a lazy SOB. I told him if he doesnt respect me and my wishes for him to take his shit out of my vehicle, then im NEVER letting him use it again. Ive been nice enough to let him borrow it for work since his POS jeep axle and front fell out compleatly. But noooo. So i told him to fuck off and im not letting him borrow it again. I borrowed his vehicle awhile ago, but i cleaned it and made sure i took out all my trash and items except for a CD he wanted to listen to.
  14. Feb 8, 2012 at 5:11 PM
    NewTacomaGirl
    Where would I find it? walmart or auto stores?
  15. Feb 8, 2012 at 5:17 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Hey those are pretty cool!! Where did you get those?
  16. Feb 8, 2012 at 5:21 PM
    babytruck
    NorCal
    Becca, looks like your "friend" had a party in your truck. I would seriously insist that he pay for cleaning or take something of his in exchange that you can sell and pay to have it cleaned.
    For me, I had EckoGuard put on mine. That stuff is all over the whole interior of the truck - seats, carpets, headliner, seatbelts, dash...everything. The interior was totally sprayed. The warranty says that if there is a stain that won't come out and if they cannot GET it out, then they will reupholster the seats. Maybe later when you come into some money you can have that done.
  17. Feb 8, 2012 at 5:23 PM
    NewTacomaGirl
    I know, i told him he needs to pay for it to be cleaned. But noooo.. his head is up his @$$ so far i know he wont. He can barely pay for child support and his $3K+ worth of bills. :/
  18. Feb 8, 2012 at 5:24 PM
    babytruck
    NorCal
    Then I think you should take something he has in exchange.
    Or kick his butt.
  19. Feb 8, 2012 at 5:26 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    I wanna say I use this stuff called Tuff Stuff
  20. Feb 8, 2012 at 5:27 PM
    NewTacomaGirl
    Oh imma do that. I could easily take his *NEW* xbox and hold it ransom. >3
    but im not that mean. He already owes me a new paint touch up job from fucking up the paint in the back. im so pissed. spent a hour outside in the FREEZING cold weather to clean out my truck.. smells better.
    Didnt think of taking pics before i cleaned it.. but OMG.. the center consol was almost black (its a light grey color), shit caked in the cup holders, mud on the doors, dust and fingerprints evertywhere...
    looks ALOT better then before i cleaned it.
