Grease on front differential?
Discussion in 'Toyota Trucks & SUVs' started by Junetaco03, Mar 16, 2019.
  1. Mar 16, 2019 at 3:45 PM
    Junetaco03
    Junetaco03 [OP] Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Hello this is non first gen related. It’s about my 1984 Toyota pickup 4x4 with a solid axle. Is it Normal for it to be having all that grease on the front differential? This is the first time I own a truck like this thanks 8199B487-8778-4B42-9247-C8FB21D826EE.jpgB1B3F86B-911F-4A4D-9816-A09635F8580D.jpg 1A0EACC0-0CCD-42F0-B22A-EFD49ADE655B.jpg
    cruiserguy likes this.
  2. Mar 16, 2019 at 3:47 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I don’t see a problem
  3. Mar 16, 2019 at 4:03 PM
    Junetaco03
    Ok great thanks for the reply. I just wasn’t sure if they have to have the grease showing how it is. But thanks.
  4. Mar 17, 2019 at 12:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what are you using to lube in there it should be a Moly grease if I remember not gear oil !!
    There are also wipers on there that with age do wear out but your looking at some major work unless your rebuilding the whole axle
    Yota Tech is great for that era truck
  5. Mar 17, 2019 at 5:28 AM
    Junetaco03
    Yeah I haven’t touched nothing there that’s how it was since I bought the truck. That’s why I’m asking.
  6. Mar 17, 2019 at 5:39 AM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Yes that is normal to have grease, Only thing I ever did with mine was clean it and replace the wiper seals. Now what does make me wonder is in your last picture to the left of the oil fill plug what the heck? it looks like it has a giant weld up and the housing looks dented.
  7. Mar 17, 2019 at 5:48 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    When it gets excessive or soupy is when you have an issue
  8. Mar 17, 2019 at 5:54 AM
    Junetaco03
    Yeah it looks like they covered it with some type of silicone
    Crodell6 likes this.
  9. Mar 17, 2019 at 6:15 AM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    Now that is the one Item I would worry about more than the rest, if that silicone comes off when a branch or bush wipes against it oil loss could be a real issue there and loss of the front drive train not good.
  10. Mar 17, 2019 at 6:49 AM
    Junetaco03
    Yeah I’m trying to figure out how to fix that issue. That’s what I get I guess for getting a free truck. Any tips?
  11. Mar 17, 2019 at 7:37 AM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    well depending on what it worth to you the solid axle truck can be awesome as an off road machine if the rest of the truck is good or worth the time and money start looking for a replacement front axle housing.
    If you can do the work yourself great if not start making friends with a few good mechanics and start learning what you need to know so you can see thru the bullshit....
    Added: I have seen them welded but yours also looks badly dented and you still will have to pull the axle anyways for best results
  12. Mar 17, 2019 at 8:04 AM
    Junetaco03
    Ok thanks for the tip I’ll take more detail pictures later on today if I have chance to see how badly it is. But the truck is I. Really good shape actually I just re did the entire engine rebuilt head plus a lot of new parts.E77B49C2-4412-4CF2-9462-B21B12F3FCB7.jpg
    Riding Dirty and DJB1 like this.
  13. Mar 17, 2019 at 8:44 AM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    Nice! that truck looks great and you can drop that off in my driveway anytime you want to leave it and forget about it...:D Personally go take the time to find a good replacement axle housing rebuild it and enjoy it.
    Riding Dirty likes this.
  14. Mar 17, 2019 at 11:46 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    A greasy mess around the aptly named "wiper" seal is somewhat normal.
    What I see is the possibility of an inner axle seal leaking gear oil into the CV joint cavity. The CV joint wants grease, the gear oil can dilute it. This leads to premature wear of the joint.
    Why? I see more "wet" than the normal grease seepage from the wiper. In fact I see drops of "wet" at the ends of the bolts in pics 2 and 3. Unless it's oil from grease that has broken down/separated I would say it's more likely from a leaky inner seal.
    And nice find.
    Toyoland66 likes this.
  15. Mar 17, 2019 at 1:47 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Yes this
    Looks like you have birf soup
    Search ih8mud.com for knuckle rebuild
    Dirty Pool[QUOTED] likes this.
  16. Mar 17, 2019 at 5:56 PM
    Junetaco03
  17. Mar 17, 2019 at 6:09 PM
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    That kit may have some stuff you do not need, such as the backing plate eliminator.
    I would recommend checking with cruiser outfitters they have an excellent reputation in the land cruiser community
    http://www.cruiseroutfitters.com/lockers.html
    About 1/5 down the page, kit FA9807TWB or kwb
    Call them and let them know what your doing and they’ll make sure you have what you need.
  18. Mar 17, 2019 at 6:23 PM
    Junetaco03
    Nice! Much appreciated!
  19. Mar 17, 2019 at 6:43 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    That looks so rad with the white steelies and softopper. First time I've lusted for a non-regular cab.
  20. Mar 17, 2019 at 6:53 PM
    Junetaco03
