Grease on the fan bracket bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Dec 12, 2024.
  1. Dec 12, 2024 at 9:30 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I replaced it 5/23. Is it ok/normal to see a little grease? It’s not on the water pump pulley, meaning what ya see in the pic is what’s there. Spins fine….
    Guess I’ve never asked whether some visible grease on bearings is ok…. I guess it would make sense that once compressed some might escape….
  2. Dec 12, 2024 at 9:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes. It’s normal.
    Nothing to worry about.
    Kristi with a K[OP] likes this.
  3. Dec 13, 2024 at 8:05 AM
    Kristi with a K
    Western MA
    Thank you! I’ve replaced a number of them, but by that time it matters not if they’re like this, in other words, it’s been determined that something’s wrong with them. & then there are others, like the timing belt ones which if you’re in there for a belt job, typically get replaced no matter what….
    TnShooter[QUOTED] likes this.
  4. Dec 13, 2024 at 11:54 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Is that an aftermarket fan bracket or where did U source it?
  5. Dec 13, 2024 at 12:25 PM
    Kristi with a K
    Western MA
    It’s an Aisin. Recommended by those in the know on here. I believe it’s what Toyota factory installed. Has a Koyo bearing, which is their goto brand. I can’t recall if I bought it on Amazon. Might be able to find it cheaper on EBay?
    https://www.amazon.com/Cooling-Pulley-Bracket-1995-2004-Toyota/dp/B0827YXLXR
  6. Dec 13, 2024 at 12:49 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Thank you!
    Honestly I would prefer to get from yota parts dealer so it is guaranteed genuine part
    Plus the discount off MSRP
    But unfortunately I was told it is not separate from the full assembly pulleys fluid coupler and all :annoyed:
