Grease Points for the 2013 Toyota, Tacoma, Access cab, 4X4, Pick-up w/V6 engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LCC1241, Jun 24, 2015.
  1. Jun 24, 2015 at 4:44 PM
    LCC1241
    LCC1241 [OP] Member
    LC
    Federal Way WA
    2013 Toyota Tacoma w/v6 engine
    None
    Researching where the different grease points are located on different models one finds himself a little frustrated because of so many configurations. This article is not intended to serve all of the Tacomas but rather the one in the title only.
    There are 5 grease points one for each of the U-joints and there are no slip joint zurks. There is NO "Cardan Joint" on this year model. Ideally, one wants to have his/her Pick-up on a rack but many times this is not the case. Most, if not all the zurks seem to be on the same side of there respective drive lines, i.e., if you turn either of the two drive lines to expose the zurks in a serviceable position the others on the shaft will also be pointing in the same direction. This information is invaluable when your crawling around under the pick-up and on the ground with a grease gun in tow.
    The hardest zurk to service is the one on the most aft end of the front drive line. The reason it is harder to service is that there is a rock guard in the way. If you are unable to rotate the drive line you can easily remove the rock guard by removing just two 12 mm bolts--makes it a little easier.
    (See--"Aft end of forward drive line")
    My purpose with this article is to render a little help to anyone trying to look up grease point on this particular vehicle. I will try and attach pictures of each U-joint to aid you in your quest. Sincerely, LC:bananadance:
    Magz, scott_b, Njdan67 and 15 others like this.
  2. Aug 21, 2015 at 1:02 PM
    DrFunker
    DrFunker Well-Known Member
    Found it LC. Great pics. These are just like on my 2011.
    Thanks.
    :thumbsup:
  3. Feb 3, 2016 at 5:46 PM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    Same on my 2015 thanks!
  4. Dec 28, 2017 at 1:31 PM
    jdlarsen
    jdlarsen Active Member
    Jon
    Castle Rock, CO
    2013 DCSB TRD Off-road
    Bilstein 5100's all around, Headstrong Offroad 2" coils in front (Bilsteins at 0), Tuff Country 1.5" aal in rear. Duratrac 265/75/16 tires on Pro Comp 7032 wheels. US Off Road low-profile winch mount with Smittybilt XRC 9.5 Gen2 winch and low-profile roller fairlead. Bakflip G2 tonneau.
    Using this today. First time doing my own maintenance on this rig after my Toyota Care was up. Great write-up. Thank you LC!
  5. Dec 28, 2017 at 3:05 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Just chiming in since I just did this again last week - make sure to get a flexible hose grease gun. If you had a hard line grease nozzle like me, buy a $5 flexible hose from eBay to convert what you already bought. This will let you access the three rear drive shaft zerks no matter what direction they are pointed while the truck is in park, and the two front drive shaft zerks. My guard shield bolts were seized - one broke off, so I have to use a flex hose to get through th opening for the hard to reach zerk in the front drive shaft. Im. It drilling out that stupid stuck bolt.
    Keep squeezing and pumping until fresh colored grease squirts out the of joints.
    Rob MacRuger likes this.
  6. Mar 13, 2018 at 4:17 PM
    Uncle HairBall
    Uncle HairBall New Member
    Harry
    Columnia, SC
    ‘13 Silver Tacoma Double Cab 2WD TRD
    All stock except for the under dash lights. Dam it’s dark inside!
    Thanks for the 411. Went full synthetic Saturday last after 38,200 break in miles. Was told there were not any lube points on most so this is where I turn for the low down. Mine is a 2 wheel drive so maybe not as many but now I have an idea where to search. Gonna jack it up when there isn’t any rain this weekend. Left her sitting in the drive for the week so no damage possible.
    Thanks again!
    And my niece nicknamed me Uncle HairBall so I’m keeping it in her memory.
    tcBob likes this.
  7. Mar 13, 2018 at 4:46 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    If you have a V6 PreRunner(2WD) then you don't have grease fittings, the 4Cyl PreRunner's have them.
    cookiedough and Lester Lugnut like this.
  8. Mar 13, 2018 at 6:34 PM
    Uncle HairBall
    Harry
    Columnia, SC
    Excellent! No worries then.
  9. Mar 14, 2018 at 5:05 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    10-4 on the V6 PreRunner(2WD) not having grease fittings.
    Beerline123 likes this.
  10. Mar 14, 2018 at 5:18 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    As far as i know, prerunners are hit and miss on grease fittings. My 4cyl prerunner didnt have the grease fittings, but my dad’s 4cyl prerunner does..
  11. Apr 15, 2018 at 10:30 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    Doing all 5 now. Thanks OP. Thanks TW
  12. Nov 10, 2018 at 12:42 PM
    GZeus24
    GZeus24 bystander
    Gary
    Texas
    2014 DCLB Sport
    lightly modified
    Big thanks for this write up. :thumbsup: I was able to get to all five with a standard grease pump. Things are a lot simpler when you know what you are looking for.
    Edit: So that didn't kill the rotational squeak in reverse. I guess its on to the carrier bearing? Perhaps I will replace all the u-joints and the carrier in one go.
    Rick_Taco and Norton like this.
  13. Nov 12, 2018 at 9:57 AM
    Skidkid
    Skidkid Active Member
    MA
    2013 Red Tacoma V6 Access Cab
    Thanks for the write up! Planning on doing this for the first time next weekend. Any suggestions for type of grease to use?
  14. Nov 12, 2018 at 10:11 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    FWIW, your Owner's Manual calls for "Lithium base chassis grease, NLGI No.2"
  15. Aug 18, 2019 at 4:08 PM
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    I have 13 points to grease, at some point will be adding two more.
  16. Aug 18, 2019 at 4:25 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Wow! Toyota was really looking out for you dude
    Norton likes this.
  17. Aug 18, 2019 at 9:19 PM
    Waited many moons
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    Points were added with upgraded suspension.
  18. Oct 23, 2019 at 1:45 PM
    GOTTER
    GOTTER New Member
    2010 Tacoma Base, 4wd 4.0 AT
    The ball in one of my zerks froze. I got it open by piking it with an awl, but then it wanted to stay open. I poked it again and it closed, but I don't like driving around wondering if all my grease is leaking out.
    It's the angled Zerk where the front driveshaft meets the transfer case--the one you have to remove that shield to get to (OP's last pic). Does anyone know where I can get this exact zerk? I can only find new U-joints, and I definitely don't want to replace the whole thing just for a bad zerk.
    Thanks for any help!
  19. Oct 23, 2019 at 1:52 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    What a pain in the ass but if you are diligent your parts will last a long time.
  20. Jul 24, 2021 at 1:59 PM
    vtdog
    vtdog Well-Known Member
    NH
    This is a very old thread, but as an original owner of an '11 I should have said how good it was when it first came out. It was (and is) a very useful bit of information. The only comment I would make is that in my experience it is not necessary to lube every oil change at 5k. I found that I was putting in so very little grease to get fitting full that I have switched to a 10k mile interval. Even with that, very little grease is needed. Also, shooting some WD 40 on the bolts which hold the gravel guard makes removing/installing the bolts much easier.
