Grease question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormtropper, Sep 14, 2016.
  1. Sep 14, 2016 at 12:22 PM
    stormtropper
    stormtropper [OP] Well-Known Member
    2013 tacoma 2.7 manual
    Yes I have searched. Ive read our trucks have 5 zerks if I remember correctly and Im trying to figure out which grease I can use. I work at a chemical plant and have access to chevron ulti plex synthetic ep, chevron moly ep2, and krytox (very expensive). Would any of these be ok to do the driveshafts and bearings? Thanks
  2. Sep 14, 2016 at 1:36 PM
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    You should go by the U-joint manufacturer recommendations.
    Spicer makes the Ujoint int he Tacoma. They make quality product and own Dana.
    Spicer recommends Mystik JT6 hi-temp grease in the Tacoma U-joints : https://www.amazon.com/Mystik-665005002080-Multi-Purpose-Hi-Temp-Cartridge/dp/B00TPA9J0I
    Per: http://www.docs.citgo.com/msds_pi/591094.pdf
    Spicer Universal Joint Division of Dana Corporations has approved Mystik JT-6 Hi-Temp Grease CLASSIFICATION: (Code 665005002) as having met M-2006-J specification for Hi-Temperature Lubricant
    And that's find with me. The Mystik grease is used in $1M mining and farming equiment, so it's good enough for my $30k Tacoma in my book.
    Yeah I know others will come and recommend other greases too. Again and again the order of Amsoil Witsnesses will relentlessly attempt to convert you to their creed.
    But why bother with anything else when the manufacturer approved Mystik JT6 grease costs only $3 a tube.
  3. Sep 14, 2016 at 1:43 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Any nlgi grade 2 grease, high pressure, hi temp grease. Any automotive store will carry this. Even wally world.
    Use the same grease in all 5 u-joints. :)
