Grease your zerks!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kris77, May 5, 2010.
  1. May 5, 2010 at 7:49 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    For those of you that don't, START.
    35k on the truck and i decided it would be a good time to grease everything.
    Jacked it up and changed the oil.
    The first 2 zerks on the front driveshaft were pretty decent. The rear ones however seemed completely empty. Took 5-6 pumps before grease was comming out the sides.
    Front ones only took 2 or 3.
    Just for your information....GREASE GREASE GREASE
  2. May 5, 2010 at 7:50 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    No problems if you just follow the maintenance schedules.
  3. May 5, 2010 at 9:22 AM
    BUDSHAD
    BUDSHAD Smartass Killa
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    Redline D6 tranny fluid. Redline gear oils in front and rear diffs. Bug shield and rain gaurds. Mossy Oak seat covers until I can afford the Wet Os.
    Did my front 2 just a few minutes ago with Mobil type 2 grease. Cant seem to find any on the rear. Thanks for the heads up.
  4. May 5, 2010 at 9:29 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I thought everything was sealed nowadays...
  5. May 5, 2010 at 9:30 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The 4x4's rear and front drive shafts have zerks fittings on the u-joints, for a total of 5 zerks. The prerunners have none. At least that's how I understand it.
  6. May 5, 2010 at 9:37 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    My 2wd 4cyl access cab has no zerks anywhere. Everything is sealed. Well maybe not the tie rod ends, I will check those. But I know the u-joints and ball joints are sealed on my 2wd. "Lube for life"? More like "lube until failure."
  7. May 5, 2010 at 10:27 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    ...what's a "zerk"
  8. May 5, 2010 at 10:36 AM
    kris77
    West Virginia
    The ones on the rear of mine just happened to be pointed straight up. Im sure if i would have jacked the rear end up I could have rotated them down. But they werent that hard to get to. I think there were 3. One next to the tranny. One in the middle. It had a skid plate covering it and then one next to the rear diff.
  9. May 5, 2010 at 11:34 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Yeah pretty much lubed until failure. I understand that the sealed ones can last 50-100K miles or so.
    It is a grease fitting or grease nipple. It is a lubrication fitting used in mechanical systems to add grease with a grease gun. The fitting is permanently installed by a threaded connection leaving a nipple connection the grease gun attaches to. http://en.wikipedia.org/wiki/Grease_fitting
    It is the green thing in the photo above.
    Clean the zerk. Then hook up your grease gun and pump some grease in.
  10. May 5, 2010 at 11:36 AM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I had my stealership grease those zerk fittings and tighten up the U joint flange on my last oil change, I don't think it was done at 35K... glad I had it done I think it was dry.
  11. May 5, 2010 at 11:37 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    The rear u joint fittings are on one of the 4 endcaps. You may have to rotate the driveshaft to see them. The front fittings are on the spiders themselves.
  12. May 5, 2010 at 11:38 AM
    BUDSHAD
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    I found the one on the rear. It was hiding from me:rolleyes:
  13. May 5, 2010 at 11:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    ...and here I thought you boys called them....NIPPLES!! :D:p:p
    Grease your nipples!!! ;)
  14. May 5, 2010 at 12:58 PM
    gcwaterski
    gcwaterski Well-Known Member
    I love greasy nipples.......
  15. May 5, 2010 at 3:30 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Really nice clear pics. Virgin grease monkeys should appreciate. [​IMG]
  16. May 5, 2010 at 3:43 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I do :p
    Oh wait those nipples....
  17. May 5, 2010 at 7:23 PM
    nighthawk87
    nighthawk87 Well-Known Member
    So what issues might your truck exhibit if you were to never grease your nipples, hehe??
  18. May 5, 2010 at 7:28 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Grinding, eventually u-joint failure which usually results in vibes, and potentially driveshaft separation (read: fucking breaks apart) if the u-joint goes unnoticed and continues to get used for a prolonged period.
    Grease your zerks people. The reg maint schedule only calls for it every 30k for chrissakes. I do mine every other oil change.
  19. May 6, 2010 at 4:04 AM
    kris77
    West Virginia
    I have that exact same gun and i never knew that was adjustable...
    Learn something new every day.
  20. May 6, 2010 at 4:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm not zerkin around, they will always be nipples...........
