grease zerk on driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buzzkill657, Sep 3, 2022.
  1. Sep 3, 2022 at 8:38 PM
    Buzzkill657
    Buzzkill657 [OP] Well-Known Member
    Jeff
    Has anyone tried to add a zerk on the rear driveshaft?
    It looks like tom woods driveshafts have them and thought why not add one to mine.
    just curious thats all
  2. Sep 3, 2022 at 8:39 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    lots of videos on youtube
  3. Sep 3, 2022 at 8:41 PM
    Buzzkill657
    Jeff
    lol im so focused on using tacoma world tonight I completely spaced youtube. no videos popped up on my google search. just videos for greasing the factory zerks
  4. Sep 4, 2022 at 9:42 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    No sense to add one. Replace the ujoint with a greasable one if so inclined. The SPL joints are stronger and less maintenance though.
    fatfurious2 and TnShooter like this.
  5. Sep 4, 2022 at 4:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    :rofl:
    You’re brave for making that comment.
    I agree with you, I’ve been in more than one discussion over this topic, and I learned my lesson.
    Lesson I learned was, the only good advice I can give is “replace when worn”. :rofl:
    6 gearT444E[QUOTED] likes this.
  6. Sep 5, 2022 at 12:02 AM
    Buzzkill657
    Jeff
    i meant where the driveshaft goes into the yoke where you get the clunking sound from
  7. Sep 5, 2022 at 12:45 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    doesn’t seem worth it. You can remove the boot and regrease it. I bet it’s something that needs to be done every 30k miles. I wouldn’t risk drilling into it for the effort required to periodically add grease but that’s just me. I am running a driveshaft from a 4runner and it has a slip yoke grease fitting from the factory, so I fill that puppy up every 5k when I check the ujoints. If I didn’t have a zerk I’d probably never check it unless it made noise lol
  8. Sep 5, 2022 at 12:46 AM
    Buzzkill657
    Jeff
    I agree with you. I will just learn to get better at dropping the driveshaft.
  9. Sep 5, 2022 at 9:52 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Are there risks of overgreasing the spline zerk?
  10. Sep 5, 2022 at 9:56 AM
    Bishop84
    Bishop84 Well-Known Member
    Yup, the seal isn't as tight and water is more likely to get it.
    Most techs and DIY'ers like to push grease in until they see it come out.
    I was always taught to pump until you hear a crackle, typically 4 pumps.
    I run sealed units now, always and forever. Same with tie rods and ball joints.
    tacoman45 and TnShooter like this.
  11. Sep 5, 2022 at 1:46 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    none I am aware of, it might cause binding if you fill the voided space entirely with grease but that’s me thinking out loud with no real world experience with that scenario. so I just give it 2 or 3 pumps, any grease is better than none.
    TnShooter likes this.
  12. Sep 5, 2022 at 2:06 PM
    TnShooter
    Deogee
    STOCK
    I’ve never had any issues, if there is a boot involved I typically go easy and watch for the boot to expand slightly. If you grease it fast and too much you “might” blow the boot off its seat.
    As for u-joint. I usually grease until I hear it crackling.
    I can’t say I’ve ever seen any real damage from having the grease come out all 4 caps.
    I’ve actually heard of 1 case where one of the passages was plugged and wasn’t greasing one of the caps. Every once in awhile, I will grease mine until it comes out all 4 caps.
    Is this a bad thing? I don’t know. But it’s what I’ve done and so far I’ve been ok.
  13. Sep 10, 2022 at 8:02 AM
    2015WhiteOR
    Gainesville TX
    Your u-joint greasing method sounds correct to me. I pump them until clean colored grease starts to come out of each side.
    TnShooter[QUOTED] likes this.
  14. Sep 10, 2022 at 8:20 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    x3
    And you get the added benefit of corrosion protection from the extra grease that is flung upward off the u-joint and sticks to metal above. :)
