Grease Zerks on 07 4x4 Offroad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Sep 27, 2009.
  1. Sep 27, 2009 at 4:41 PM
    OffroadToy
    OffroadToy [OP] This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I was under the impression there were 5 zerks total on my 2007 offroad 4x4...all on the 2 piece drive shaft (propeller shaft and slide yokes). I just read there could be up to 8 zerks. Are there zerks common to the front drive shaft thrust bushings?
  2. Sep 27, 2009 at 4:49 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    believe both ends of the front driveshaft.
    one on each u-joint and one on the slide shaft?
  3. Sep 27, 2009 at 5:04 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    There are 5 zerk fittings total, one on each u-joint. On the three rear driveshaft the zerks stick out on the outside of one of the 4 u-joint bearings on each joint, on the front driveshaft the zerks are located in the center of the joint.
