Greased drive shaft today
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, May 19, 2019.
  1. Jun 6, 2019 at 6:34 AM
    #61
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The front driveshaft rotates while driving in 2 wheel drive.
    Vbpiper likes this.
  2. Jun 6, 2019 at 6:37 AM
    #62
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    o_Oeven when the 4wd is not engaged
  3. Jun 6, 2019 at 6:38 AM
    #63
    shakerhood
    Southern Ohio
    Correct.
  4. Jun 6, 2019 at 6:38 AM
    #64
    BillsSR5
    bill
    2014 SR5
    you sure your not talking about the CV Axles?
  5. Jun 6, 2019 at 6:44 AM
    #65
    shakerhood
    Southern Ohio
    If I am not mistaken the front driveshaft always rotates.
  6. Jun 6, 2019 at 6:49 AM
    #66
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I'm not so sure. You can manually rotate the front driveshaft with your hand when the T-Case is in 2wd, I would think this wouldn't be possible if the driveshaft always rotated.
  7. Jun 6, 2019 at 6:54 AM
    #67
    shakerhood
    Southern Ohio
    I could be mistaken but remember someone on here marking it, driving around and it ended in a different position, maybe it was testing something else though.
  8. Jun 6, 2019 at 7:03 AM
    #68
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Lubricant drag in the front differential case.........
  9. Jun 6, 2019 at 7:09 AM
    #69
    Extra Hard Taco
    R.J.
    Devil's Island
    Could be, I'm going to have to mark my front drive shaft and see if it moves after driving.
    shakerhood[QUOTED] likes this.
  10. Jun 6, 2019 at 7:14 AM
    #70
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    Tag for later
  11. Jun 6, 2019 at 7:53 AM
    #71
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You are not mistaken.
    There have been a few who have either zip tied it or greased and has eliminated some vibration. I would not skimp on the front driveshaft.
  12. Jun 6, 2019 at 8:25 AM
    #72
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
  13. Jun 6, 2019 at 8:27 AM
    #73
    lynyrd3
    Bill
    East Central Upstate NY
    Arise Sir Loin of Beef :rofl:
    DrFunker[QUOTED] likes this.
  14. Jun 6, 2019 at 8:59 AM
    #74
    DrFunker
    DrFunker Well-Known Member
    :rofl:
    lynyrd3[QUOTED] likes this.
  15. Jun 6, 2019 at 9:40 AM
    #75
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    If the driveshaft is bone dry, would it be making any type of noise? When I have my back sliding window open, I hear a sort of metallic shearing noise almost. Gonna grease my driveshaft this weekend, just curious about it.
  16. Jun 6, 2019 at 9:57 AM
    #76
    shakerhood
    Southern Ohio
    Your truck most likely only has Zerks on the front driveshaft.
  17. Jun 6, 2019 at 10:34 AM
    #77
    BillsSR5
    bill
    2014 SR5
    on my 2nd gen it does not, im absolutely sure unless the 4wd is engaged the front drive axle does not turn, unless you have fulltime 4wd or AWD
  18. Jun 6, 2019 at 10:48 AM
    #78
    shakerhood
    Southern Ohio
    Right, Tacoma's do not have full time AWD.
  19. Jun 6, 2019 at 10:50 AM
    #79
    RobZ9132
    RobZ9132 Well-Known Member
    Somewhere in NC
    2004 Double Cab TRD
  20. Jun 6, 2019 at 11:09 AM
    #80
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    Do you clean off excess/waste/old grease? I use a paper towel to get the big chunks of grease off, then use brake cleaner, and a shop towel.. always pump until you see clean grease.. if you are doing front end work remove the ball joint covers and remove old grease.. install and be sure to pump up with new grease afterwards. its not a horrible idea if you dont care about dust to smear the grease on common rust areas.. it will collect dust/dirt, but acts as a barrier to rust forming/spreading. its simmilar to how fluid film works, however its hard to keep fluid film on a rotating part, inertia just flings it off at high speeds....
