Greasin' my zerks...
Discussion in 'Technical Chat' started by LonghornTaco, Feb 12, 2009.
  1. Feb 12, 2009 at 6:45 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Sounds like a old 70's porno! :D
    Anyway, I think I need to grease my UCAs. I don't think I put enough in there when I installed it and it's squeking a little now.
    What do I need to do it?? And how much grease do I use?
  2. Feb 12, 2009 at 7:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    make sure that u use some PB Blasters on the uniballs. thats wher ei get squeak from every now and then
    and as for the UCA's, go to autozone and get a grease gun w/ a flexible hose and a zerk attachment. i bought some high friction valvoline grease for mine
  3. Feb 12, 2009 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mobil1 and lucas red and tacky #2 are good greases...................i use both on my drive shafts zerks.....................gotta do it again soon.
    get a pistol grip grease gun too....................way better than the standard arm.
  4. Feb 12, 2009 at 7:43 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    and just pump enough into it so it oozes out
  5. Feb 13, 2009 at 7:38 AM
    LonghornTaco
    Minnesota
    Thanks guys!
    I think I read somewhere that you can put too much grease in if you pump until it "oozes out"... Or is that if you keep going after the oozing begins??
    And you'll have to forgive me, but what is PB Blasters? Is it something I smear on the uniball to clean it or is it a spray or something?
  6. Feb 13, 2009 at 7:53 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    It's a "creeper" type lube, spray can like WD-40 but better. Creeper type is where it works itself into all the small places it can get to. I guess it "wicks" is a better term.
    Don't use grease or a white lube on the uni-ball. It'll trap road dirt and grime and then you have gritty grease and it'll be like sandpaper in there. Eventually you grind the hell out of it. PB Blaster can be purchased anywhere you get automotive stuff. All the major auto parts stores, Wal-Mart, Lowe's, Home Depot...You get the point. It frickin' stinks but works well.
    When you grease....ooze is ok as long as it JUST pops out. No need to make it squeeze out like toothpaste. Also a good idea to wipe the excess off to because of the above mentioned grit grab.
  7. Feb 13, 2009 at 8:01 AM
    LonghornTaco
    Minnesota
    Awesome!
    Do I need to remove the wheel to do this or can it be done with the wheel on? I know I can physically get to all of it with the wheel on, just wondering what people "in the know" do... :)
  8. Feb 13, 2009 at 8:32 AM
    TicTacOma
    Columbia,SC
    Someday I "will" be in the know. You should be ok with just turning the wheel left and then to the right so you can fit in there. Grease it and then take a short ride. Just work it in.
    Also.....Tripleqwazzible check your clothes for grease, that stuff just leaps on to you without notice. You'd cry very, very loud getting that stuff on your seats.
  9. Feb 15, 2009 at 9:47 AM
    LonghornTaco
    Minnesota
    Yesterday, I went and got a grease gun (pistol grip type) and tried to grease the UCAs. However, it seemed that more grease came out of nozzle than made it into the zerk (if any...)
    Is there a secret trick to doing this right?
  10. Feb 15, 2009 at 9:50 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Make sure the grease gun nozzle engages the zerk all the way... mine leaks out of the nozzle a little bit, but not bad...
    listen for the pop and you're good...
  11. Feb 15, 2009 at 9:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like you didnt put enough on when you installed them. First, DO NOT USE PB BLASTER OR ANY OTHER PETROLIUM LUBE ON THE UNIBALLS. This will ruin them fast. I dont care what anyone says. DONT DO IT. Use a Dry tefflon lube, if any. Also, you may want to loosen the UCA bolt, and then grease the bushings. If the grease isnt going into the zerk, make sure your grease gun has a positive connection to the zerk.
  12. Feb 15, 2009 at 10:02 AM
    LonghornTaco
    Minnesota
    umm.... Well, I already put the PB Blaster on the uniball..... How bad did I mess it up?
  13. Feb 15, 2009 at 10:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dam!!!!!!
    Go get some Tri Flow and soak the Uniball in it. If its not that dusty in your area, you will be ok. That PB Blaster will eat through the Tefflon coating in the Uniball cup.
  14. Feb 15, 2009 at 10:05 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    :eek:
    note to self: always ask Chris first...
  15. Feb 15, 2009 at 10:07 AM
    LonghornTaco
    Minnesota
    So, just detach the uniball from the spindle and soak it for a while or do I need to take the whole UCA off? And how long do I soak it? just a few minutes or an hour plus?
  16. Feb 15, 2009 at 10:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Neither. Just spray a good shitload on the top of the ball and let it sit. Then, after an hour, spray some more, and goe for a ride, makeing sure to cycle the front suspension a few times to work the tri Flow in. Whatever damage, if any, is done, you cant erase it.
  17. Feb 15, 2009 at 10:15 AM
    LonghornTaco
    Minnesota
    Thanks Chris! I'll run out and get some in a few minutes...
    Tri flow? It's in a spray can like the PB Blaster?
  18. Feb 15, 2009 at 10:46 AM
    jhodge83
    SC
    17 XLT Sport
    sorry dude....i was just going off what allpro told me. i'm taking chris' advise as well and trying to find some of the tri flow he told me about
  19. Feb 15, 2009 at 11:04 AM
    LonghornTaco
    Minnesota
    I went to three auto parts stores around me and none had Tri-Flow. However, I did find this... Liquid Wrench's Dry Lubricant. And the can says "With Cerflon". Maybe the word teflon is copywrited or something??
    Anyway, is this basically the same thing?
  20. Feb 15, 2009 at 11:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I still cant belive that All Pro is telling people this. Im thinking its why their Uni's are so noisy, and fail often. Good for repeat business........I guess......
    That should work. Everything I have found on that product sugests it does in fact have PTFE (Tefflon) in it. Regardless, its better than any oil based lube. :)
