Greasing ball joints w/o grease zerks: Light Racing, etc.
Discussion in 'Suspension' started by jstanley, May 16, 2015.
  1. May 16, 2015 at 12:08 PM
    jstanley
    jstanley [OP] Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    So, installed my LR UCAs with my lift and got to wondering about greasing them. Of coarse they don't come with grease or any zerks to grease them, so...
    Just pop this into the end of our grease pump and pump the grease in.
    If you don't want to poke holes in the boot, a small screwdriver can be used to pry the boot out enough to insert the needle. You may want to have someone hold it so it doesn't stab through the boot while you're pumping grease in. :anonymous:
    I found the needle at Northern Tool today, less than $4 each. They also sell them on Amazon.
    Biscuits likes this.
  2. May 18, 2015 at 7:15 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    In all honesty that doesn't lube the joint at all. just fills the boot with grease.
  3. May 19, 2015 at 5:09 AM
    gearcruncher
    Canadain bumper technician
    I believe what Buzzcut is saying is true . One of the seminars I went to explained that polyurethane joints were factory sealed and designed to last 50,000 miles which is considered a lifetime joint . The same goes for universal joints that are pre-lubed from the factory and then sealed with no grease zerk .
    Some guys spend the time and actually drill directly into a polyurethane universal joint trunnion and then add a grease zerk . I cant honestly say its a true fix . If the lubrication for some reason goes dry on a sealed joint , the joint in question should be replaced .
    I am one of the old school guys who believe its still best to use universal joints / ball joints etc that utilize grease zerks . Water finds a way in . If you have the ability to flush water out with a grease zerk , chances are the joint will last longer than a sealed joint . The problem with flushable joints is people dont flush them enough . Read what Spicer has to say http://www2.dana.com/pdf/J3299-2-DSSP.PDF
  4. May 19, 2015 at 11:32 AM
    jstanley
    Central TX
    Wasn't aware of that, seems hard to believe. I've seen several posts about the ball joints on these arms being short lived so figured they needed greasing. Oh well, some grease in the boot shouldn't hurt anything.
