Greasing Front Driveshaft with Skids
Discussion in 'Armor' started by Bengt18T, Nov 23, 2016.
  1. Nov 23, 2016 at 8:52 AM
    Bengt18T
    Bengt18T [OP] Well-Known Member
    Chambersburg, PA
    13 Taco DCSB TRD Sport
    I will more than likely be getting full skids in the near future but thought of a question when I was under the truck greasing the driveshafts. How do you grease the front driveshaft when you have a trans skid? Doesn't this cover up the already limited access to the shaft? Do you have to drop the skid every time (which seems like a pain) or is there a way to snake something in there?
  2. Nov 23, 2016 at 11:28 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I greased mine right before I installed RCI skids last week. I'll take a look under later today to see if it can be done without removing them.
  3. Nov 25, 2016 at 2:29 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I just checked and I will still be able to grease my driveshaft zerks without removing the skids. There is access from the driver side.
  4. Nov 26, 2016 at 8:17 AM
    Jtaoj0
    Jtaoj0 Well-Known Member
    I have skids to the trans and can grease all of the zerks.
  5. Dec 15, 2016 at 2:03 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Even if it WAS blocking your access to grease it....couldn't you take it off by removing something like 4-6 bolts?
    Prayn4surf likes this.
